Old 06-25-2013, 08:30 PM   #1
Pro Performance
Pro Performance's Avatar
McGaughys Rear 13" Big Brake Kit
We have a Rear Big Brake Kit from McGaughy's in stock, that was returned from a customer. He decided to go a different direction. We are selling this kit at a discount for $575 + shipping.
Note: This is a plain rotor kit, NOT cross drilled or slotted.
http://www.azproperformance.com/McGa...202-64203.html
Pro Performance is offline   Reply With Quote
Old 06-27-2013, 01:14 PM   #2
Pro Performance
Re: McGaughys Rear 13" Big Brake Kit
TTT.... I will include shipping for this $575 price.
Old 07-29-2013, 12:54 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
What axle does it fit? Is there any chance of getting the drilled rotor?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-29-2013, 05:08 PM   #4
HotRod C/10
HotRod C/10's Avatar
Travis,
do you sell the e-brake cables for this caliper setup?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 07-30-2013, 03:20 PM   #5
Pro Performance
It is for the 12 bolt rear end, but I believe most 10 bolts have the same backing play bolt pattern and axle offset for this kit, but not for certain.
The rotors can be swapped and can get them, but the cost of shipping the rotors back and having new ones shipped to you, will be expensive. Probably cheaper to have them drilled locally, or whoever does the machine work for the axles.
Originally Posted by HotRod C/10 View Post
Travis,
It will come with e-brake cable setup to work with the caliper.
Keep in mind, this kit does require machine work to the rotor and axle of the truck. The center bore of the rotor must be opened up, and the outside axle flange must be turned down to fit inside the rotor.
Old 07-30-2013, 07:29 PM   #6
HotRod C/10
I should have been more clear........I have the same calipers, just need the cables or are they just Seville cables I can get locally
Thanks!
David
LS SWAPPED
-1976 SILVERADO
Old 07-31-2013, 12:07 PM   #7
Pro Performance
David,
I am not sure, as the ones that come with the kit are basically adapters to work with that ebrake pull on the caliper. McGaughys might sell them to you separate, but other than that, I am not sure where to get them.
Travis
Old 07-31-2013, 02:55 PM   #8
nlped
nlped's Avatar
To try & help out... You only have to machine the centerbore of the rotor... OR have the axle "hub" turned down to match the centerbore of the rotor (I did the latter because I didn't want any Issue when it was time for new rotors), the axle flange fits inside the rotor fine.
I've used this kit on a 10 bolt from my old '82 square, my '76 Blazer with a 12 bolt & now my '70 and it worked with all 3.
And I ended up getting my parking brake cables from Lokar because the ones in the kit wouldn't work.
Hope this helps
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-31-2013, 03:36 PM   #9
Pro Performance
Good know about the e-brake cables. I have had customers that had to turn down the axle flange as well...maybe just due to variations throughout the years.
Old 08-06-2013, 01:25 AM   #10
Pro Performance
TTT, PN of this kit is 64202
