Old 08-04-2013, 02:21 AM   #1
nheller76
nheller76's Avatar
New motor break in time
So I just put a 355 with in my truck and its about time to start prepping and getting her some run time. So the block is not new but my cam is so what should I do to get her ready to get on the road. I'm getting the oil pump primed soon and I'm wondering how long I need to have her run before moving her. Any masters at this and what should I do?
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 08-04-2013, 02:27 AM   #2
Redcap
Re: New motor break in time
20 minutes above 2500rpm.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 08-04-2013, 09:57 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Follow these procedures. http://www.73-87.com/7387garage/driv.../newengine.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 08-04-2013, 11:10 AM   #4
SCOTI
SCOTI's Avatar
I agree w/the steps suggested in that link but will add that break-in oil & additives are a must if you're breaking in a motor w/a hydraulic flat tappet type cam.
I filled the oil filter w/the additive & topped it off until full w/break-in oil. Fill the crank case up w/the remaining break-in oil. Get the valves set as close as possible & timing as well. You want it to be able to start quickly & do the initial cam break-in w/o fuss.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-04-2013, 01:56 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
20 min idle it 2300-2800 rpm. Varying it as Time passes after ten min it's when you know all is well.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-05-2013, 12:33 AM   #6
nheller76
nheller76's Avatar
So foot on the pedal for 20min that works
Old 08-05-2013, 01:01 AM   #7
INSIDIOUS '86
If you want to sit there. I usually start it up and usd the idle screw to keep it there and vary the rpm every five min to splash lube different parts of the cam.
Make sandwich have a beer. Watch the temp and the oil press and enjoy watching your newbies come out wondering what's going on haha
Old 08-06-2013, 01:35 PM   #8
nheller76
nheller76's Avatar
Yea I will definitely have Neighbors come out I don't have an Exhaust on it yet! I'll let u guys now how it's going when I get there.
Old 08-06-2013, 02:14 PM   #9
gchemist
gchemist's Avatar
Keep a water hose handy to spray down the radiator if it starts to heat up.
Old 08-06-2013, 02:42 PM   #10
nheller76
nheller76's Avatar
Smart idea I don't want it to overheat
Old 08-06-2013, 02:42 PM   #11
nheller76
nheller76's Avatar
Old 08-06-2013, 03:17 PM   #12
INSIDIOUS '86
That's how I do all my engines haha. Reminds my neighbors to be thankfull I do out exhaust on mine. Last time it was a freinds big block and it shook and rattled the neighborhood
You can say thier jimmies were rustled when he left with cutouts open and a John force burnout haha.
Old 08-07-2013, 08:16 AM   #13
tgh117
Crazy
tgh117's Avatar
Mine was so loud without the exhaust, I actually had ear muffs on when I went back into the garage and adjusted the idle and checked on the vitals.
Its pretty neat to hear it purring like that, and have people walked up and be like what do you have going on in there?!?
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
