Lifted 2wd?
Has anyone here ever lifted a 2wd truck? I know I'm probably in the minority, but I really don't like the look of lowered trucks (sorry). My '70 C20 has stock suspension on it now, and when I pull up beside newer 2wd trucks, even 1/2tons, they're all sitting up higher than I am.
I know one of Chevy's major selling points was that their trucks sat lower than the competition, thus making them ride more like a car. But nowadays, even modern sedans ride higher than they did back 40 years ago. My question: has anyone lifted a 2wd truck? If so, what did you use? I'm not looking for a huge lift so I can fit 35s under it, I just want to sit up higher on the road.
White70C20 1970 Blue C20 - 250, 4 speed 1985 Ford Thunderbird 2005 Pontiac G6 |
Rusty Nuts
Re: Lifted 2wd?
They used to make twist in coil spring spacers that would give you a little lift but not much. it would keep your springs from collapsing so much. I had them on my 67 in the 80's.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
Re: Lifted 2wd?
I think they make spacers that will go under your front springs to give you about an 1-1/2 of lift. I think I have heard some people using Jeep coils in the back maybe these could work.
http://www.carid.com/1998-jeep-wrang...Fc5FMgod4DkAag |
Re: Lifted 2wd?
Thanks, guys!
I forgot to mention some vital information. My truck is a 3/4 ton with the "Custom Camper" package. It has heavy duty leaf springs in the back. (I'm assuming most 4x4s had leaf spring rear ends too?) Basically, I was wondering if a lift kit for a '67-72 K20 would fit on my C20? Or if anybody had had luck swapping in different components to make them higher.
Re: Lifted 2wd?
The rear is easy. With leaf springs you can run blocks, or lifted springs or a shackle flip.
The front is more of a problem. 4WD trucks had leafs in the front also. How about a small body lift?
Re: Lifted 2wd?
You are not alone...someone just asked about raising the front of his C-20...front springs from a 73-87 crew cab dually was suggested.
http://67-72chevytrucks.com/vboard/s...d.php?t=594365
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
Re: Lifted 2wd?
Thanks guys,
That's great 'n all, but what I'm after is making my C20 the same height as a more modern 3/4 ton 2wd. My grandfather has a '95 C2500 (basically the same as mine only 25 years newer) and it sits up significantly higher than mine. Granted, it's only 18 years old and only has 58,000 miles, vs. my 43 year old truck with 68,000 miles. Am I just asking too much from old technology?
![]() Join Date: May 2002
Re: Lifted 2wd?
Stock height these things weren't but 33"-35" from the ground to the top of the fender well. What's yours sitting at now?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
![]() Join Date: Apr 2008
Re: Lifted 2wd?
Try buying a new set of springs for a big block truck. Your springs have probably settled a couple of inches over the years.
Re: Lifted 2wd?
may not be what you are after but 16" steelies and a 235/85 will raise the stance
Figure out what you want--then figure out what you are willing to give up to get it. Last edited by Lou Boffa; 08-29-2013 at 02:51 PM. Reason: fat fingered |
Re: Lifted 2wd?
I could be wrong but I think he is looking for something even taller. Probably some way to get his suspension high enough to put some 35" tires under there and still have plenty of room.
The rear would be pretty simple with leafs in the rear. Front is more of a challenge. May have to look at some newer trucks and their front suspensions to see if any can be swapped out. I remember in the 90's seeing alot of aftermarket parts in the magazines to raise 2wd trucks. I know.. probably no help at all
71 swb 350/4sp manual 5/7 static drop |
Re: Lifted 2wd?
There is about an 8" difference in curb height between a 72 and a 2012. Much of that is the cab interior height and the fact the floorpan sits pretty much flat on top of the wider frame. Trying to raise the truck that much is going to be costly to have it done right and still ride like a street truck. A set of taller front springs, rear blocks and 33" (255-85R 16 for example) tires should do a lot without killing the ride.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: Lifted 2wd?
Here is a write up of a forum member (Dino) who change the ball joints to accept a later model lift spindle. In my opinion, this would be the ideal way to go, since it won't effect ride at all. You can also put a lift springs in there also to get additional height, like he did. He is using the 88-98 Chevy truck lift components.
Hope you find this link helpful. http://67-72chevytrucks.com/vboard/s...d.php?t=282398 |
Re: Lifted 2wd?
Here is another on a square body.... same idea.
http://67-72chevytrucks.com/vboard/s...d.php?t=469743 |
#15 |
Re: Lifted 2wd?
Cool, thanks guys!
I was out looking at my grandfather's old '70 C20 he parked in amongst the other old farm machinery he didn't use anymore. Though it's sunken down into the dirt a little bit over the last 25 years, it seemed to me that the distance between the top of the wheel well and the tire is about the same as my truck (the two are virtually twins). I want to drag it out and get a good look at it sometime. It has a 250 I6 in it, where mine has a 350 so mine could be sagging a little in the front from the extra weight. I still would like to lift my C20, but I think I'm going to put it on the back burner for right now. Thanks again!
#16 |
Re: Lifted 2wd?
Put a 3 or 4 inch body lift on it, no suspension mods req'd.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#17 |
Petroleum User
Re: Lifted 2wd?
If you do a body lift, it shows the frame a lot more than at stock height, so make sure its lookin good
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
#18 |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Re: Lifted 2wd?
Just saw this thread and thought I would chime in. I'm with you on the lowered trucks (not for me). That's the beauty about these trucks... there are so many options. Check out my picture link below. When I did front disc conversion I changed out the front springs. I installed some HD springs (P/N 2772074) bought from NAPA. Tires do not rub at all. They are 285/70-17 tires with H2 Hummer wheels. The ride is a bit stiff, but hey it's a 3/4 ton truck. Here's a comparison of the springs:
The stock HD C20 springs are as follows: http://www.napaonline.com/Catalog/Ca...752_0162319756 Part No.: 2771752 No. of Coils: 7.92 Free Height: 12.94" Spring ID: 3.68" Spring Load Height: 10" Design Load: 2950 Spring Rate: 1016 Wire Diameter: 0.812" The springs I put on from C10, C20, C30 from 1973-83. They are as follows: http://www.napaonline.com/Catalog/Ca...074_0162301536 Part No.: 2772074 No. of Coils: 8 Free Height: 13.61" Spring ID: 3.676" Spring Load Height: 10" Design Load: 3841 Spring Rate: 1060 Wire Diameter: 0.83" You could also use C30 mid '80's 1-ton springs, but I thought they would be too stiff. Those are: http://www.napaonline.com/Catalog/Ca...085_0162304063 Part No.: 2773085 No. of Coils: 7.93 Free Height: 13.34" Spring ID: 3.65" Spring Load Height: 11" Design Load: 3289 Spring Rate: 1318 Wire Diameter: 0.906"
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#19 |
Re: Lifted 2wd?
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
#20 | |
Re: Lifted 2wd?
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
#21 |
Re: Lifted 2wd?
I used Performance Online 8-lug conversion kit. It was straightforward and customer service was very good.
