Old 09-16-2013, 02:48 PM   #1
NC_John
NC_John's Avatar
Sticky Clutch Pedal??
I've got Blue roaming around some now (went two counties over to meet my wife for lunch today which was pretty brave).
One recurring issue that I have is the clutch pedal "sticks" to the floor, seemingly more so when the truck is cold. It does it less when I've been driving a bit but still does it once and a while. The clutch seems to be operating normally otherwise but this is obviously pretty annoying.
I've lubed everything I can see and greased the fitting I found on the horizontal shaft. The assembly looks to be slightly crooked from the frame to the engine/transmission but I don't believe it is actually bent or damaged. I haven't come across another one yet to see if this is normal. The return spring is intact. I might could try replacing it with a newer one to get a stronger return pull.
Anybody had this issue? Any suggestions? I can't find anything binding when inspecting it under operation (though it is hard to tell).
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
