Old 01-15-2013, 04:12 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
1972 Chevrolet C10 OEM fuse block & under dash wiring harness no guages no AC
Entertaining all offers!!!
This is an interior wiring harness and fuse box that was removed from a running a driving 1972 Chevrolet C10 pickup. The truck did not have gauges, it had "idiot" lights. It also did not have A/C. This harness will fit other 67-72 chevy trucks, but I cannot guarantee anything.
I cleaned the harness with soap and water after I removed it from the truck.
This harness can be modified to work with stock gauges. I can do this modification for an additional charge if needed.
As mentioned above, this harness was removed from a running and driving truck, but it is not without issues:
1. In the photos, there is some heat damage to the headlight switch plastic plug. The wires do not appear to be damaged and the headlights were functional.
2. In the photos, the connector for the dimmer swich is missing. I believe I have one from another harness that I can install
3. The black wire for the wiper motor has had a crimp connector installed.
4. The grey wire for instrument and panel lights has been cut. I did not think to check if the instrument lights were working before I removed the harness and I didn't have a wiring diagram at the time.
5. There is a brown wire that has a terminal but no connector. From my research, my best explanation for this wire is circuit #25. My wiring diagram explains circuit 25 as "GENERATOR OR GENERATOR ARMATURE TO VOLTAGE REGULTOR "A" (INCLUDES GENERIC TELLTALE CIRCUIT OR REGULTOR TO IGNITION SWITCH (TRUCK)
$75 shipped USPS to the lower 48 sates, you cover the paypal fees.
WIDESIDE72 is offline   Reply With Quote
Old 01-21-2013, 03:25 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: 1972 Chevrolet C10 OEM fuse block & under dash wiring harness no guages no AC
photos
Old 01-21-2013, 03:30 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
more photos
Old 01-25-2013, 12:57 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
Any offers?
Old 02-07-2013, 03:54 AM   #5
WIDESIDE72
WIDESIDE72's Avatar
ttt
Old 03-09-2013, 02:09 AM   #6
WIDESIDE72
WIDESIDE72's Avatar
ttt
Old 03-28-2013, 07:45 AM   #7
WIDESIDE72
WIDESIDE72's Avatar
Ttt
Old 03-31-2013, 09:01 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
Ttt
Old 07-05-2013, 08:47 PM   #9
greyno3
greyno3's Avatar
Still Have this wiring harness? I am located in Spokane, WA. i'll send this to my brother. He has paypal. Thanks!
greyno3 is offline   Reply With Quote
Old 07-05-2013, 09:00 PM   #10
WIDESIDE72
WIDESIDE72's Avatar
Talking Re: 1972 Chevrolet C10 OEM fuse block & under dash wiring harness no guages no AC
Yes i do still have it. Pm sent
Old 11-03-2013, 09:43 AM   #11
WIDESIDE72
WIDESIDE72's Avatar
Ttt
I also have a fuse box and harness for trucks with gauges that has no defects $100 shipped
Inside underdash ac harness one burnt connector $30
Buyer covers fees if paypal
Old 11-09-2013, 06:21 PM   #12
altunaa
hi, i need just the fuse box, can you split? shipped to miami, fl
best regards
altunaa is offline   Reply With Quote
Old 11-09-2013, 07:38 PM   #13
WIDESIDE72
WIDESIDE72's Avatar
best regards
I have no idea how to get it apart and no time to do so if i did. Makeme an offer on the whole thing. Not trying to get rich, just make some money to finish my dads truck for him.
