Old 09-14-2013, 01:53 AM   #1
Robert Bergstrom
Robert Bergstrom's Avatar
3.07 Posi OK?
I just found out my posi is a 3.07. The stamping on the outside of the gear is 14 43 and when you do the math it says 3.07. Am I doing this right? I was hoping for a 3.75. I know freeway rpm will be great but won't be doing hours of that. Does a 200R overdrive transmission have a steeper first gear?
Vancouver Bob
Robert Bergstrom is offline   Reply With Quote
Old 09-14-2013, 02:02 AM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: 3.07 Posi OK?
Sounds like you have a 3.07 alright. A 700r4 has a steeper first gear than a 2004r. Do you have a bbc sbc or 6 cyl? Imo a 3.07 is too high of a gear for an od trans and it will hunt too much if you encounter hills. Iirc Gm never installed an od trans in front of anything higher than 3.42. A bbc might have the torque to mask this
WIDESIDE72 is offline   Reply With Quote
Old 09-14-2013, 02:07 AM   #3
Robert Bergstrom
Re: 3.07 Posi OK?
ZZ4 engine half ton fleetside. If I am not mistaken GM had a 3.07 stock with 80 and 90 V8 performance Camaros with a 700R.
Vancouver Bob
Old 09-14-2013, 02:10 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
Re: 3.07 Posi OK?
I meant to say trucks. The taller tire of a truck just makes the actual gear ratio higher. Try it for yourself and see what you think. I wasnt happy and swapped the 3.07 to a 3.73 in my 72 swb with a mild 350.
Old 09-14-2013, 02:11 AM   #5
jocko
jocko's Avatar
Re: 3.07 Posi OK?
TH350 (1-3) = 2.52/1.52/1.00
TH400 (1-3) = 2.48/1.48/1.00
2004R (1-4) = 2.74/1.57/1.00/.67
700R4 (1-4) = 3.06/1.63/1.00/0.70
700R4 has best 1st gear to make up for the 3.08. But concur with wideside, your biggest concern will be the lugging in the 45-65 mph range. If you don't do much highway driving, I'd just swap the rear gears to something a little steeper to increase your off the line perf (that sounds like where your concern lies) - or - IF you want good highway mileage also, then swap both (2004R or 700R4 and 3.42 or 3.73).
Old 09-14-2013, 06:21 AM   #6
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Re: 3.07 Posi OK?
3:08 is too tall for an OD trans IMO- 3:73 works great
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 09-14-2013, 08:26 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Re: 3.07 Posi OK?
Don't know if you have seen this thread or not.
http://67-72chevytrucks.com/vboard/s...d.php?t=596343
Some good info in it....
LockDoc
Leon
Old 09-14-2013, 03:01 PM   #8
Fitz
Re: 3.07 Posi OK?
Drive Train Specialists (DTS) and others have both the 3.48 and 3.73 ring and pinion sets for your truck. The 200R trans you have is perfect with 3.48 gears. Your ZZ4 Motor is a bit strong for the 700R4 trans which is rated at a max torque of 360 ft- lbs. If that were my truck i'd keep the 200R4 trans and switch the ring and pinion set with a 3.48 set of gears.
Fitz is offline   Reply With Quote
Old 09-14-2013, 03:07 PM   #9
cdowns
cdowns's Avatar
Re: 3.07 Posi OK?
you cant just switch gears you'd need a new posi or open carrier to do it
Old 09-14-2013, 03:17 PM   #10
Robert Bergstrom
Re: 3.07 Posi OK?
Thanks, have not decided on the trans yet but a 200R with 3.42 sounds good. I may go up to 3.73 if I can find a good deal on the gears somewhere. Thanks everyone for the input it has pointed me in the right direction.
Vancouver Bob
Old 09-14-2013, 04:55 PM   #11
Bigdav160
Bigdav160's Avatar
Re: 3.07 Posi OK?
Is this a 12 bolt truck axle?
Anyone know what the case split is?
3.42 and down; 3.73 and up, is that correct?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-14-2013, 05:39 PM   #12
slow-1
slow-1's Avatar
Re: 3.07 Posi OK?
After the other recent discussion on thishttp://67-72chevytrucks.com/vboard/s...d.php?t=596343, I took my truck today to run some errands here and there.
I purposely drove it in OD and purposely drove slow. With my combo (mild 350/700r4/3.08 rear end gears, I could drive at 40 mph with no problem at all, going up hills at 40 mph, I could keep it at 40 and even accelerate without it changing down to 3rd...not stomp on the gas accelerate, just real world from 40 mph to 55 mph accelerate.
Drop down to 35 mph, it always changed to 3rd, but stayed there until I got back up to 40 mph or above.
3.73 or 3.42 may be the optimum ratio, but 3.08 is acceptable to me, your results may vary.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 09-14-2013, 06:24 PM   #13
Average Joe
Average Joe's Avatar
Re: 3.07 Posi OK?
Personally I'd try the 3.07's. Allow me to explain my reasoning.
Your zz4 makes very good torque at a lower rpm than many other cammed up small blocks. Look at the cam specs. It is very short on duration but long on lift. Something like 208 and 212 @ .050 IIRC. This makes for a lower torque curve. Plus a 10 to 1 comp. ratio with aluminum heads makes for efficiency as well as power. However detonation could be an issue on a hot day or poor fuel. You may have to play with the timing to get it dialed in. Acceleration would definitely be better with either a 3.42 or 3.73. I presume the reason you went with an overdrive was to improve hwy MPG and get lower rpm. This combo should attain that. Board member gchemist runs the same combo and claims close to 20mpg hwy. Now if memory serves he is in the flat midwest but so is the willamette valley. I personally would try them first before spending lots o'cash on a new settup. Just one Average Joes 2cents.
Average Joe is offline   Reply With Quote
Old 09-14-2013, 06:38 PM   #14
lha1992
lha1992's Avatar
Re: 3.07 Posi OK?
GM built lots of 88-98 GMT-400 trucks with a 350FI, 700R4 and 3.08s. My 89 came like that from the factory with 235-75R15 tires.
I just rebuilt and built up the 700R in my truck and getting ready to switch to 3.73s in it.
lha1992 is offline   Reply With Quote
Old 09-14-2013, 07:54 PM   #15
LONGHAIR
Re: 3.07 Posi OK?
Not true at all. In fact, in half ton trucks, you would be less likely to find one lower than that. In the early years of the OD transmissions they used gears as high as 2.56......in a 4x4 no less. They were extreme duds, made worse by bigger tires.
I replaced dozens of 2.73s and 3.07s back in the day.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-14-2013, 10:24 PM   #16
Fitz
Re: 3.07 Posi OK?
Since the breakpoint for resizing the carrier is 3.08 small and anything shorter, large no matter what he does except keep the 308 means changing the carrier.
Old 09-20-2013, 05:11 PM   #17
Robert Bergstrom
Re: 3.07 Posi OK?
I have series 3 posi 12 bolt. My understanding 3.42 is the steepest gear that came from the factory for a series 3, but 3.73 are sold now that have the thicker gear and will work in a series 3. Decisions, decisions...
Vancouver Bob
