Old 09-15-2013, 11:10 PM   #1
chvyboy
chvyboy's Avatar
Exclamation Any holley fan out there?
My question is, is a holley 870 cfm too big for a sbc?
Details that might help:
383 stroker/ 450 hp
2004-R transmission
My project: Spare change
http://67-72chevytrucks.com/vboard/s...=1#post5031992
chvyboy is offline   Reply With Quote
Old 09-15-2013, 11:13 PM   #2
sduckworth13
sduckworth13's Avatar
Re: Any holley fan out there?
This might help you decide
http://www.holley.com/applications/C...bSelection.asp
Scott
sduckworth13 is offline   Reply With Quote
Old 09-15-2013, 11:31 PM   #3
mmiddle
mmiddle's Avatar
An 870CFM is awful large for any small block. Granted if you are running 350+ CID and a blower, maybe.... Generally, 750CFM will adequately supply even a well built 400. Vacuum secondary's are the key.
I vote no... way too big. Engine vacuum will suffer and not enough airflow to signal the venture boosters to draw fuel into the air stream. Drivability will be terrible at best. Now if you were to build an all out drag engine....
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 09-15-2013, 11:41 PM   #4
chvyboy
chvyboy's Avatar
Lucky enough I was gifted this Holley 870, so ill throw it on and if it doesn't work as well as I want than I will buy a 770 dp
Old 09-15-2013, 11:51 PM   #5
Syndrome
If its new it will be worth more as it is instead of used. Might as well use the gift for what you need.
1970 GMC
Syndrome is offline   Reply With Quote
Old 09-16-2013, 12:35 AM   #6
mmiddle
mmiddle's Avatar
If you are dead-set on a Holley, sell the 870 and buy a 750 Vacuum single pump with electric choke. Double pumper manual secondary's are a major waste of gas.
Plus, being in CA, how are you planning to slide that past the Smog Cops?
Here in Texas, old cars only needs a safety inspection and "visual" check for smog stuff if so equipped.
Mark
Jesus is the Way!
Old 09-16-2013, 06:38 AM   #7
68C15
blood type; Retumbo
68C15's Avatar
sounds like a decent size carb, if you're running 8000 rpm
I would go with a 750 and annular boosters up front and conventional ones in the back. This will drop the cfm a bit yet increase the signal and give much better atomization. Make sure you get them tilted 3* out when you seat them. An aftermarket block would be a great improvement as well. For tuning it you will need a non-dampened vacuum gauge. That way you can see just how low the vac. gets for power valve selection.
Do you know much about tuning the transition circuit? That's where 90 % of driving is done
with time, patience, and skill you can make a Holley drive like fuel injection, run like a raped ape, and get surprising fuel economy
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-16-2013, 06:50 AM   #8
Fitz
383 stroker/ 450 hp
2004-R transmission
Your engine is basically an air pump. The flow rate in cubic feet per minute is related to displacement and revs by the following formula:
Flow in CFM=(Displacement in Cu In * RPM * volumetric efficiency)/3456
a perfect VE is 1, so at 6000 rpm, your 350 cu in motor flows 600 CFM. Now we all know that no one ever gets a perfect VE (meaning it is always less than one) and that the flow is also influenced by manifold, heads and valve lift so adding a carb capable of flowing that figure with a little margin takes us to 700-750 CFM.
870 is a bit large for that motor. Dropping down to a 750 would likely perform better. Don't believe it??? My ZZ572 runs a Holley 850 CFM double pumper and is not lacking power.
Fitz is offline   Reply With Quote
Old 09-16-2013, 07:03 AM   #9
TBONE1964
Cluster King
TBONE1964's Avatar
READ THE PLUGS!!!
Black plugs are bad.
Tan plugs are good.
Reading the spark plugs will tell you if the engine is running efficient or not. I would agree a 870 cfm does sound a little large. You may have to put smaller jets in it for it to work well.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 09-16-2013, 09:43 AM   #10
A real simple loose rule of thumb I go by,that works,is 2 cfm per cubic inch. Technically it's 2.? cfm,but that works.
Old 09-16-2013, 03:57 PM   #11
68C15
blood type; Retumbo
68C15's Avatar
that will just limit the amount of fuel and make it run even worse. Imagine this. you drink from a cup with no problem. now drink from a 5 gallon bucket.
Old 09-17-2013, 05:39 AM   #12
eldogg
eldogg's Avatar
Is it a 870cfm Street Avenger? if so it will be close out of the box just lazy. a 770 would be a lot better but I understand running what you got. I agree with ^. Read the plugs and run at least 14 degrees (16-18 would be better) of base timing and no more than 36(most 383's with good heads like 32-34) total. If you have any question just send me a PM. I will try to help as much as I can.
eldogg is offline   Reply With Quote
Old 09-17-2013, 06:58 AM   #13
NC_John
NC_John's Avatar
good analogy!
If the motor is stock or just mildly built I bet a 600/650 will work great. I put a 750 on what I thought was a "built 350" (the first engine I built- way too much of everything and nothing matched) and it looked fantastic when the hood was open but was way too carb.
For 99.9% of street applications, smaller is better!
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 09-17-2013, 08:48 AM   #14
68C15
blood type; Retumbo
68C15's Avatar
BINGO!!!!!!!!!
I had an 80 K20 with a 11:1 355 and a holley (kind of). a 4776 main body (600dp staged progressive secondaries), 750 base plate, re-tapered venturis, stepped annulars in front, dog-leg conventional in back, and Percy's blocks. Although I had close to 80 hours building and tuning it, I have never seen anything work better. 17mpg at 70 with 33" tires, 3.73:1 gears and a NP465. Throttle response was stellar and so was performance. Driveability was better than expected from such a combination
Old 09-17-2013, 09:26 AM   #15
72bowtiestepper
good analogy!
You are correct !! I changed my big block Camaro to a 600cfm carb from the 750 I was told to use by a so called "expert" & it really woke up that motor .....very crisp throttle response with the 600 w/ vac. secondaries on the street...better gas milage to boot !
72bowtiestepper is offline   Reply With Quote
Old 09-17-2013, 09:56 AM   #16
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Well... my SBC sees a lot of runs above 6,000 RPM's and the 3310 on it is perfect. It's really not a "street" engine to most of you... but high RPM's, loose converters, big heads, and big carbs are "street" to me.
So I'm in the .1%
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-17-2013, 09:41 PM   #17
That's the problem with too much carb. You don't drive around at 6k.
Old 09-17-2013, 09:50 PM   #18
mmiddle
mmiddle's Avatar
If more is better, Then too much is not enough! Is not a good philosophy for carbs and cams.
Most street driven SBC's will never need anything larger than a 750 Vacuum.
Run what you want... to each his own.
Mark
Jesus is the Way!
Old 09-18-2013, 08:01 AM   #19
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
I just got through replacing a worn-out (puking gas) Quadrajet from PO with a Holley Street Avenger 670 c.f.m. On my basically stock 350 engine it runs and performs well. Started almost immediately and after a few simple adjustments (Checked float level - CHECK, minor tweaking of the idle mixture screws - CHECK, and set idle speed - CHECK) it runs super. I couldn't be happier. My truck runs as well as it ever has and cold-starts great. I will admit, I have run many Holley carbs and I can rebuild them in my sleep, but for now, I am super satisfied with this one. DITTO to what others have said about c.f.m. Too big is asking for problems. I worked in a "real" SpeedShop back in the day, and too much carb/too much cam was like a plague.
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
TobyArnot is offline   Reply With Quote
Old 09-18-2013, 08:34 AM   #20
Daddy Brim
Daddy Brim's Avatar
In California no smog check, no inspections on these old trucks. I think 1976 is the cut of date, not sure. All DMV wants is your $$$.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 09-18-2013, 10:14 AM   #21
chvyboy
chvyboy's Avatar
I guess my next question is if it can be jetted down?
Old 09-18-2013, 03:55 PM   #22
68C15
blood type; Retumbo
68C15's Avatar
yes, the same way you can take small sips from the 5 gallon bucket. I tried it a couple times and was quite unhappy. You will have major dead spots when you drive it.
