Old 09-15-2013, 10:37 PM   #1
iceship
rear disc brakes
Will the backing flang off a 96 impala rear disc brakes fit on a 85 c10. ... I know the kits are cheap. .. I just like the fact that I can just get everything I need at one of the local parts yard. ..
iceship is offline   Reply With Quote
Old 09-15-2013, 11:25 PM   #2
bdiamond
Re: rear disc brakes
I just bought a caprice rear yesterday. No, the backing plates will not fit without modifications. The truck uses a larger housing end than the car. There aren't any in the local salvage yard here. I looked all over for this one.....
bdiamond is offline   Reply With Quote
Old 09-16-2013, 09:16 AM   #3
iceship
Ok thaks... guess I'll have to order or get a bracket made. .
Old 09-16-2013, 02:45 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Just order a kit from Capt Fab in our Vendor marketplace. I understand your desire to use over the counter parts, but the brackets are not a "wear item" . Once they are installed you shouldnt ever have to worry about them again.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-16-2013, 05:31 PM   #5
DREAMER1
DREAMER1's Avatar
Enlighten us o'wise Squarebody Gurus. I really don't understand that well. I've seen a few "kits" for rear disc brakes go for around $500. What's this bracket that's needed? Once we install the bracket, then we can install disc brakes from an impala? If so, what years are recommended?
DREAMER1 is offline   Reply With Quote
Old 09-16-2013, 05:40 PM   #6
Unca
a set of weld-on brackets for stock cars can achieve the same end. if a person has a mind to do so. I'm a more out of the box thinker then some. but that's how we put disc brake rears on rock crawling jeeps. brackets. calipers and hardware off a mid to late 80's midsize GM. banjo bolts, lines and pads gtg... there are some calipers w provisions for an emergency brake as well... some web research can tell you part numbers n costs and I'm sure somewhere has a video showing the task.
Unca is offline   Reply With Quote
Old 09-16-2013, 08:15 PM   #7
bdiamond
The bracket bolts to the housing end and the caliper carrier bolts to it. You can use whatever caliper you want, he makes several brackets. If you use the Impala setup I'm not sure if the parking brake assembly will be retained with the Captainfab brackets.
Old 09-17-2013, 02:43 AM   #8
andrewmp6
If you want a e brake http://67-72chevytrucks.com/vboard/s...d.php?t=382633 the impala ones http://www.67-72chevytrucks.com/vboa...77#post3259777
Old 09-19-2013, 12:34 AM   #9
iceship
And that for putting impala front disc on the rear ..
Old 09-19-2013, 02:54 AM   #10
andrewmp6
Both kits use impala rear rotors the camaro caliper kit has a e brake the impala kit don't have a e brake.
Old 09-19-2013, 05:31 AM   #11
Pop's C-10
Pop's C-10's Avatar
There are few guys that have put tha whole B-body axle under there...tha width is different..but i don't think by that much
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 09-21-2013, 02:10 AM   #12
EddiesLow77
So what would be better just get the bracket or jus change the whole differential out and can some what tell me what year exactly you need if u wanna get the brackets orfrom what car exaclty i really wanna do it after reading this
EddiesLow77 is offline   Reply With Quote
Old 09-21-2013, 03:22 AM   #13
andrewmp6
The rear end swap is not a bolt in you'll have to cut off all the mount tabs and weld on spring perches and shock mounts,Not sure if you have to mess with the drive shaft or not.On the two bracket kits read the post in them they list what rotors and calipers you need to have.
