Cant drive 55 Literaly
Running a 250 with a single barrel rochester carb, points. Did a tune up because of poor performance still having an issue. New distributor cap, points, plugs, vacuum advance. Points are set on 19, timing is set 4 over without advance when advance is plugged back in timing advances to around 12-15 over. Problem is truck will not get above about 45 mph. any thoughts? carb issue maybe??
