Old 09-29-2013, 11:50 AM   #1
cheyguy
cheyguy's Avatar
Blazer top trim strip question
....you know that piece of trim that goes on the inside lip of the top before it's bolted down? Does anybody know if a set from any other years will work for 73-75. I've talked to a few guys that "assume" they all are interchangeable, but I want to make sure before I spend time and $ hunting some down. Thanks in advance.
'71 Cheyenne Super
'80 Custom Deluxe
'75 Blazer
cheyguy is offline   Reply With Quote
Old 09-29-2013, 08:43 PM   #2
Willowrun
Willowrun's Avatar
Re: Blazer top trim strip question
The outside (dirty) pieces are off of my '73, the inside pieces are off of my '79. As you can see, the length and angles are a little different, but the form and bolt holes seem to be the same so I think you're good with the later model pieces.
Old 09-29-2013, 09:26 PM   #3
cheyguy
cheyguy's Avatar
Thanks a lot! I appreciate you putting the picture up, it helps me out a bunch. I would love for them to have been the same, but at least I can settle for the ones that should be easy to find until I can find the right ones.
'71 Cheyenne Super
'80 Custom Deluxe
'75 Blazer
