Old 09-19-2013, 02:31 PM   #1
LT1 Burb
LT1 Burb's Avatar
Rim ID help needed
Does anyone know what year these are off if. I can't see a stamping on them and bought them for my 65. They look like they have beauty rim nubs on them which I don't recognize.
LT1 Burb is offline   Reply With Quote
Old 09-19-2013, 03:00 PM   #2
1963c-10
1963c-10's Avatar
Re: Rim ID help needed
Do the faces of the rims have 3 or 4 bumps for the caps?
1964 Short bed trailer
Old 09-19-2013, 03:13 PM   #3
LT1 Burb
LT1 Burb's Avatar
There is 4 of them.
Old 09-19-2013, 04:13 PM   #4
1963c-10
1963c-10's Avatar
That would make it 71+ blazer, jimmy or 4wd rim...and some vans. I have never seen one w/beauty rim bump. I have 6 off a 73 4wd, but no beauty ring bumps. I have a buddy big in the 73-87 world....I can ask him what he knows on them.
Im guessing its a 15" rim?
Edited...had to correct the date and add the van applications
Old 09-19-2013, 04:20 PM   #5
1963c-10
1963c-10's Avatar
What about the stampings on the outside of the rim? That'd help some. For example...These are May 1971 6 lug 4 bump here
Old 09-19-2013, 07:26 PM   #6
LT1 Burb
LT1 Burb's Avatar
They are 15's, I looked high and low and can't find a stamping anywhere.So they used these rims with the bump outs for the brake drum rivets until 72.
Old 09-19-2013, 08:26 PM   #7
1963c-10
1963c-10's Avatar
Im not 100% sure. What I was told by the 73-87 guys was the 4 bump face started in 73 and was used until around 91. And they were made for disc brakes...Ive only seen the 4 bump style like what I have, but I dont have trim ring bumps. I pulled the trim rings off my 63 6 bump rims and the trim rings fit the same, but my rings have the retainers on them, not the rims. Im not sure the make or application for the ones you have.
Old 09-19-2013, 08:30 PM   #8
LT1 Burb
LT1 Burb's Avatar
I am sure if they were on my 65 no one would know if they were correct or not.
Old 09-19-2013, 08:39 PM   #9
1963c-10
1963c-10's Avatar
I agree, I don't think that it really matters, as long as you like them. I went to the 4 bump 73 style rim because I wanted to retain my factory hubcaps and trim rings, and they clear disc brakes. The 4 bumps have a slightly longer opening on them, but its not really noticeable...and hey...I like them. Can you post a full size pic of them? Might help someone else in the future possible id them. Im interested to see it also. They might even clear disc brake calipers too.
This is what my 4 bumps look like....all painted up, just waiting to afford some wide whites to put on them.
Old 09-19-2013, 08:48 PM   #10
1963c-10
1963c-10's Avatar
One more note...any numbers would be stamped on the inside of the rim...you'd have to unmount the tires to see them.
Old 09-19-2013, 09:02 PM   #11
LT1 Burb
LT1 Burb's Avatar
The reason I went to these is because the rims I powder coated don't have the bumpouts for the rivets do they don't fit square. These ones do but they have the nubs on them that my factory suburban rim didn't have.
Old 09-19-2013, 09:04 PM   #12
LT1 Burb
LT1 Burb's Avatar
Old 09-19-2013, 09:07 PM   #13
LT1 Burb
LT1 Burb's Avatar
Ones on my truck now.
Old 09-19-2013, 09:18 PM   #14
1963c-10
1963c-10's Avatar
ahhhh, i see now. they are three bumps. i have a stack of them, ill go look through them tomorrow. your 4 bumps look like mine
Old 09-19-2013, 10:57 PM   #15
oem4me
Now we would, silly. You shouldn't of said anything. Ok if I call you Mr. wrong wheels from now on? LOL
Old 09-19-2013, 11:26 PM   #16
jtrichard
you could grind the heads off of the rivets also then your wheels would fit and look like the ORG. unless you pull the cap off
jtrichard is offline   Reply With Quote
Old 09-20-2013, 09:24 AM   #17
LT1 Burb
LT1 Burb's Avatar
Yeah, I thought about that but the powder coating didn't turn out as great as I wanted anyways so I am going to have another set done somewhere else.
Old 09-20-2013, 09:25 AM   #18
LT1 Burb
LT1 Burb's Avatar
I was counting the nubs on the outer rim that would hold on a beauty rim. There is 4 of them.
Old 09-20-2013, 09:54 AM   #19
HOTFUN
HOTFUN's Avatar
If they have 4 nubs they are disk brake used 71 up. If you check back side of will be square corner stamp to clear caliper. 65 will be 3 nub and back will be rounded out to edge of rim. But the 71 up wheels will fit fine. Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is online now   Reply With Quote
Old 09-20-2013, 07:11 PM   #20
60-66
60-66's Avatar
Its been my experience with NOS rims that when they have the "beauty Ring nubs" they are GMs over the counter rims. They did the same thing with car rims in the 60s and they are NOT originals, but are replacement parts. The markings will all be between the beads, not on the outside= Rim date and manufacturer. There was just 3 NOS 1960 rims on Ebay, 3 clip style and I darn near bought them till I saw the nubs on the outer edge of the rim. None of my original rims have those extra nubs. Still nice rims but not correct. Another way to identify these wheels is the valve stem hole size, larger is 63 and earlier on the 15 inch rims.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-20-2013, 08:21 PM   #21
1963c-10
1963c-10's Avatar
Thumbs up Re: Rim ID help needed
between the beads is what i meant about outside of the rim, thanks for the proper term 60-66
Old 09-21-2013, 10:30 AM   #22
LT1 Burb
LT1 Burb's Avatar
Thanks guys, we will see how long it takes at shows for the first person to notice they are over the counter rims. Any guesses, they were 10 a piece and are a matching set so I thought they would work better than the newer ones I have.
Old 10-14-2013, 08:16 PM   #23
LT1 Burb
LT1 Burb's Avatar
Here is the stamp mark on the inside.
