Old 10-20-2013, 05:16 PM   #1
lt1tyrell
5.7 Vortec swap
I have been working on a fixing a few things on a 66 C10. So far it has ben lowered and I did an s10 T5 swap. Now I am looking into swapping a 350 vortec engine in. I want to do it cheap and keep my transmission and bellhousing set up. I am aware that I will need to use an intake manifold for the carb conversion and run an electric fuel pump. Also plan to use an electric fan and old style ram horn exhaust manifolds. So what will I need as far as motor mounts and is there anything else I should be aware of to make the clutch linkage work with the V8? Thanks.
lt1tyrell is offline   Reply With Quote
