ignition switch
i tried removing the spacer off the ignition switch. all it does is keep spinning. i think it might be stripped. so i can't get apart the spacer and the bezel off the ignition switch assembly.
What do you recommend for replacement parts? Im pretty sure i will need a new ignition switch.. how do you remove the switch from the spacer? do you unplug it? how does it come apart? Thank you.
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
