Old 01-06-2015, 07:02 PM   #1
87Skier
87Skier's Avatar
Homemade trailer hitch reciever
I have a homemade trailer hitch on my truck and have been thinking about replacing it. Would you guys trust a homemade one?
It attaches to the side of the frame in 4 places and made with 1/2" steel plate (no that isn't a typo). It is basically just a large flat plate with a store bought receiver welded on.
Is it safe to use?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 01-06-2015, 07:23 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Homemade trailer hitch reciever
wow whats that about 150 pounds off the truck!!
1967custom
michael bustamante is offline   Reply With Quote
Old 01-07-2015, 10:29 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Have you used it? It looks pretty stout. I guess it depends on the welds, which we can't see.
LockDoc
Leon
Old 01-07-2015, 10:49 PM   #4
Cape Codder
Cape Codder's Avatar
I would use it for light towing up to maybe 750lbs. It doesn't matter if it's 1/2" plate it is still just a flat piece of steel that can flex. The longer the piece the more chance of it bending. I tow with a hitch that I adapted to my truck from a jeep. It is a square tube hict that I had to make my own end plates to mount to the truck. I welded a piece of angle to both flat bars that go up to the frame.
Cape Codder is offline   Reply With Quote
Old 01-07-2015, 11:53 PM   #5
87Skier
87Skier's Avatar
I haven't used it and I know its 20+ years old since it sat for about 20 years. The welds actually look good for something someone made at home, and somehow the sides where it connects to the frame (through the bumper bolts) there is half inch plate that is bent around the bottom and welded on. I think it would hold up under regular conditions but at some point I think I would hit the brakes and the boat would continue through the back of the vehicle.
I'll probably go with something like this:
http://www.carolinaclassictrucks.com...-receiver.html
Old 01-08-2015, 02:01 AM   #6
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I've built the hitches for a few of my rigs and trust them. However, one that's simply plate I wouldn't trust with more than a 1000lb trailer, if that.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 01-11-2015, 07:51 AM   #7
87Skier
87Skier's Avatar
Well, I'm planning on towing the boat with it this year, but it weighs about 3200 lbs, so this won't be used.
