What's left of a 1968 3/4 ton 2wd. BEING SCRAPPED FRIDAY 9/13!!
Hey guys, last chance before this thing heads to the scrap pile. It's a 1968 Chevy 3/4 ton 2wd. I'm literally going to cut it up into small pieces so if there is anything you would like, let me know. I'm keeping the 4 speed, rear end, trailing arms and top of cab by visors.. The rockers are rusted but the floor and firewall is decent. windshield is broke. Frame is solid, and straight. It is a coil-sprung 3/4 ton. Has a good 250 Ci. Inline 6. Will cut sections of the frame, suspension or cab or bed. Whatever is left on the morning of 9-13-13 (Friday!) will be scrapped!! So, speak up!!
Prices are as follows: ANY section of frame under 12". $20 PLUS Shipping. ANY section of body under 12" x 12" square. $20 PLUS shipping. 250 Inline 6. $50 pickup only. any misc interior parts still on it, $10 or under PLUS shipping. (Includes cluster and glovebox door!) ![]() ![]() There is no radiator, it has been sold, just an old pic. ![]()
"Repetition penetrates even the dullest of minds" |
member
Re: What's left of a 1968 3/4 ton 2wd. BEING SCRAPPED FRIDAY 9/13!!
I'll take the cluster.
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
Petroleum User
I'll take the glovebox door
Posted via Mobile Device Is the driver side cab corner any good?
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto Last edited by 71sierragrande; 09-11-2013 at 10:01 PM. |
Is it a SWB OR LWB?!?
Interested in bed molding if good driver quality Posted via Mobile Device |
olblue60: You do see that the cluster bezel is broken correct? IF so, it'll be $25 shipped to you.
71sierragrande: Glovebox door is yours for $10, the driver cab corner is in fair shape, has some bubble issues but not terrible. WV1967LWB: The truck is a long bed. The trim is in poor quality, both bedsides have a massive dent in almost the exact same spot, which both dents got the trim. it is missing a piece on the drivers bedside i believe.. some of it is bolted? on through the trim itself. Overall, it's some rough trim parts, but if you wanted all the trim, i'd do $10 plus shipping for all that is on the truck. EDIT: FORGOT TO MENTION, I ONLY TAKE USPS MONEY ORDERS!! I DO NOT HAVE A PAYPAL!
#6 | |
Petroleum User
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
![]() Join Date: May 2012
Is the bed floor steel or wood?
Garage Built |
steel, it holds water fine, no rust holes. especially clean back by corners of tailgate area.
I could use a small patch panel about 10 inches square at the rear center of my bed where a fuel door was made. I could get exact measurements if you want but what would that cost with shipping to 57110?
Garage Built |
I can cut you a 12" by 12" section for $40 shipped to you, can you give me a general area where you'd like it cut at?
It's alsways something.....
![]() Join Date: Nov 2008
do you have the side trim off the passenger door and passenger front fender? I also need the trim for both cab corners
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
I'll take the left and right upper cowl corners (vertical areas above and parallel to the firewall). Also, what condition are the rear wheel housings in, and what would be my cost on those shipped? My zip code is 32159.
member
Try spinning the speedo with your fingers. If it is working, send me your address. Thanks
Do you still have the hood? If so any pics?
#15 |
If you are willing to cut up part of the bed I need the rear drivers side part of the bed just in front of the stake packet to the tail light inside and outside skin shipped to 37110 thanks
#16 |
![]() Join Date: Aug 2012
how about the mirrow arm and mirrows. I see them on the door. Don't care what side or if one one. Let me know.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
#17 |
I have decided I WILL NOT scrap this until Tuesday (9-17), but after that it's gotta go, The city is on my a** about too many "junk" vehicles. haha.
Chuckmc8: I have no fender or door trim for a 68. the only trim that is decent is the cab corner trim. I'd take $16 shipped to you. Bassetlust: I can cut your patch panels out if you can show me a picture of what exactly you want. The wheel tubs are decent, but have some small dents. Will take $100 plus shipping for the parts described. ($20 for each patch panel and $30 for each wheel tub.) olblue60@aol.com: cluster's speedometer does spin when i manually spun it. PM coming your way. aftamathe86: Yes i will cut the taillight area out on the driver side, back by the taillight area does have some surface dents. Will do $35 shipped to you. Gdavis, I do not have time to take the door apart for the mirror arm, if you wanted, i can cut around the mirror in like a 8" by 6" square and send you the arm, mirror head that is broken, backing plate and the piece of door between the two. I'd take $16 shipped to you. @homebuilthotrods: I'd do $40 shipped on that patch panel for your bed.
#18 |
Can you send me a pm with an email or cell number is I can send a pictures so I know we are on the same page thanks
#19 |
"Chuckmc8: I have no fender or door trim for a 68. the only trim that is decent is the cab corner trim. I'd take $16 shipped to you."
Thanks, I bought what I needed today
#20 |
Petroleum User
I also need the single piece of lower passenger side bed trim(In front of rear wheel, behind the door, i see it in your pics, it's under 3 ft long). I would like it even if not in good condition. Thanks
#21 |
Aftamathe86: I can do that for you. still will be $35 shipped to you.
71 Sierragrande: Okay, I can do a total of $60 shipped to you, including that piece of trim. (The trim is in rough shape.. It's bent pretty bad.. Just don't want any surprises.) OlBlue60@aol.com: It looks like it'll be $25 shipped.
#22 |
PM sent - I will have pics of the patch panels needed by Saturday.
#23 |
Petroleum User
Well lets skip the trim piece then, it looked straight in the pic. Just the gb door and the cab corner for me please
#24 |
What about the radiator? Will it hold water? lol I need one for a v8..
1970 SWB "old flame" 1967 SWB c10 sold 1972 Elcamino 496 2012 Denali HD dmax |
#25 |
I sold you that long bed to early. I also need 2 door latches and bolts. Also need striker plates, shims, and bolts..
