Old 12-01-2010, 07:08 PM   #1
evan
evan's Avatar
Looking for rear diff info
Is there a thread somewhere that has info on what different rear ends were offered on these trucks? Also, how much power they can handle stock and recommendations on how to beef them up?
Evan B.
evan is offline   Reply With Quote
Old 12-01-2010, 10:17 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Looking for rear diff info
This may help a little.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 12-01-2010, 10:35 PM   #3
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
hmm so I either have 2.76, 3.07 or 3.73.....
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 12-01-2010, 11:24 PM   #4
rblcori7
rblcori7's Avatar
yeppers ive got 3.73's and a 10 bolt
84 Short bed 350: Hooker headers, flow master 40 series, edelbrock Intake manifold, Holly street avenger carb, 4 inch skyjacker suspension lift, 33x12.5 Toyo Open Country Mud Terrains, 3.73 gears
2011 Silverado LTZ
rblcori7 is offline   Reply With Quote
Old 12-02-2010, 12:01 AM   #5
datguysaL
my 85 c10 swb silverado shows 2.42's for rear end gears according to the glove box label. its a 10 bolt.
datguysaL is offline   Reply With Quote
Old 12-02-2010, 05:25 PM   #6
evan
evan's Avatar
I'm going to be building one truck out of two. One of them has a 10 bolt and the other has a 12 bolt. Is one stronger or more desirable than the other?
Evan B.
Old 12-02-2010, 06:11 PM   #7
thesickc10
go with the 12 bolt
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 12-02-2010, 06:35 PM   #8
68 TT
Still plays with trucks
68 TT's Avatar
Use the 10-bolt.
The truck 12-bolt has a smaller diameter pinion bearing and is weaker than the 8-1/2" 10-bolt. The 10-bolt uses the same pinion diameter as the car 12-bolt.
The new body style trucks & SUV's use a larger 30-spline axle in their 8-1/2" 10-bolts so you can easily find 30-spline carriers that will fit into the older 10-bolts as an upgrade to make them nearly as strong as the car 12-bolt.
You will need to buy new axles to put the 30-spline carrier into your older axle housing but for less money you can pick up the whole rear end out of the new body style truck instead.
It is a little wider than the square body part but that is good as it puts the rear wheels closer to being aligned with the front wheel position. All you have to do is remove the perches and relocate them to the right spot for the square body.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 11-09-2013, 07:46 PM   #9
520CheyenneK10
Now my 73' has the dana 44 front but my 12 bolt rear has 3.07 gearing as does the dana front. according to the chart my rear diff should have something else but I removed the cover and counted and it is stamped with the gear numbers. 14 and 43 which is 3.07
520CheyenneK10 is offline   Reply With Quote
Old 11-10-2013, 01:33 PM   #10
Keith Seymore
Keith Seymore's Avatar
Base axle will typically not be shown on the SPID (or it will show "GQ1" base axle with no ratio specified).
Optional ratios will show on the SPID, both the RPO code and the noun name (GT4 = 3.73 axle ratio).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
