Old 11-12-2013, 08:55 PM   #1
BK72BURB_3/4Ton4x4
BK72BURB_3/4Ton4x4's Avatar
Third door hardware - inside handle to latch bar
Third door does not open from the inside and finally got around to pulling the panel off to see why. I found the bar from the inside handle to the latch was missing, dug around on the bottom of the door and unfortunately didn't find it there It doesn't seem to match the passenger door configuration since the lock is on the opposite side?
First question - Can someone confirm that this bar is unique to others?
Second question - If the answer to question one is yes, does anyone have an extra one laying around they'd be willing to part with?
thanks in advance,
Brian
BK72BURB_3/4Ton4x4 is offline   Reply With Quote
Old 11-12-2013, 09:26 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Third door hardware - inside handle to latch bar
It isn't still attached to the door latch part and hanging down is it?
I will try to remember to look tomorrow. I have to go for a hearing test in the morning so it won't be until afternoon sometime.
LockDoc
Leon
Old 11-14-2013, 09:32 PM   #3
LockDoc
LockDoc's Avatar
I finally had a chance to check this today. The third door remote rod is all by itself as far as length and shape. While I had it out I made a copy of it from a pickup rod. If you still need one I will send the copy to you for 5 bucks postage...
LockDoc
Leon
Old 11-15-2013, 12:21 PM   #4
BK72BURB_3/4Ton4x4
Yes please...sent PM with address info.
Old 11-15-2013, 09:01 PM   #5
LockDoc
LockDoc's Avatar
PM returned...
LockDoc
Leon
