Old 10-12-2013, 06:56 PM   #1
bharrison1
bharrison1's Avatar
Mcgaughys flip kit shock mount problem
So i got it all put together now it looks like i need to modify the bottom plate to mount my shocks .What the hell?
bharrison1 is offline   Reply With Quote
Old 10-12-2013, 07:46 PM   #2
bluex
bluex's Avatar
Re: Mcgaughys flip kit shock mount problem
Ya I had to trim one on my djm kit too. I also had to buy extra washers to put between the shock an the extender because the extender was to wide. I used two on each side of the shock...
bluex is offline   Reply With Quote
Old 10-12-2013, 08:25 PM   #3
durty harry
durty harry's Avatar
If you not going to use shock extenders your going have to do some grinding to the plate and to the shock nut and bolt .
Its a pain to do had to do the same with mine .
Scott
82 step side aka " Bouncy "
73 GMC
Long bed Vortec 5.7
durty harry is offline   Reply With Quote
Old 10-12-2013, 08:57 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Weld on a shock extender. Gives a better angle anyway and smoother ride
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-13-2013, 08:36 PM   #5
rudey737
I have McGaughy's 4.5/6 drop kit uninstalled at home. Has anyone talked to McGaughy's about this? They don't recommend shock relocation brackets, just their lowering shocks. They don't even mention that thismight be an issue.
Obviously, this is a problem with other flip kits as well. Is it possible to flip the bolt fir the shock the other way so the head is on the side of the spring plate?
rudey737 is offline   Reply With Quote
Old 10-13-2013, 09:53 PM   #6
INSIDIOUS '86
Don't trust a company's advise when they stand to gain profit from it. Run shock extenders. Djm is worse at this as well run the head of the shock bolt on that side and try and gain clearance.
Old 10-13-2013, 11:25 PM   #7
rudey737
Will stock length shocks work with the extenders in the back, or will I need to run shorter shocks?
Old 10-13-2013, 11:59 PM   #8
INSIDIOUS '86
They should work fine unless your running drop shackles and a notch. Should be able to touch frame
Old 10-14-2013, 02:09 AM   #9
INSIDIOUS '86
At least I was able too on mine with the extenders. But I had the same issue
Old 10-14-2013, 02:38 AM   #10
bluex
bluex's Avatar
If you do that then you'll have to remove the spring plate to change the shock....
Old 10-14-2013, 09:28 AM   #11
Hertzdaddy
That's what I did. I'm not planning on removing my shock anytime soon.
Hertzdaddy is offline   Reply With Quote
Old 10-14-2013, 10:09 AM   #12
rudey737
bharrison, did you get this figured out? I'm curious what you did to "correct" this. Did you buy shock extenders? Did you flip the shock bolt? Did you clearance the flip kit spring plate?
I'll be running the flip kit and a bolt in c-notch. It also looks like I'm going to be ordering some shock extenders so I can keep my stock shocks for the rear.
Old 10-14-2013, 11:14 AM   #13
rudey737
I have one other question, bharrison1. It looks like you have new u-bolts. Do you happen to know what size the u-bolts are?
Does anyone know, are the u-bolts pretty universal for all squarebodies?
Azulita - 84 Chevy Scottsdale Longbed 305/350
Old 11-16-2013, 08:11 PM   #14
bharrison1
bharrison1's Avatar
i pulled it apart and shifter things around a bit and it worked no trimming the u bolts are these http://www.rockauto.com/catalog/more...724&cc=1030093 hope this helps sorry it took me so long to respond
