Carter Carb Help needed
Hey All,
I rebuilt the Carter 9635 AFB carb on my kids pickup the other day. It runs great but I'm in need of help hooking up vacuum hoses. Looking at the carb from the front, the 5/32 port on the left (passenger) side goes to the distributor, center 3/8 port goes to PCV. Where does the 5/32 port on the right (drivers) side go? This carb has an electric choke which also has a 5/32 nipple on it that has vacuum when running, where does this go? Thanks for your help!!!! Also the 3/8" port on the left side labeled emissions, where does this go to. it's a '69 GMC so there's no charcoal canister, I've just routed it up into the base of the air cleaner. I'm not sure if this is the correct place. Here's a picture, can anyone fill in the blanks? ![]()
Take Care Troy |
