Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Closed Thread
Old 02-02-2014, 07:33 AM   #1
Sharps40
Want to Trade for I6 Iron Headers
Looks like I have an intake. Still hopein to locate Cast iron exhaust headers, I suspect the Langdons are the only ones out there in cast iron for the 194-250 engines. Let me know if you want to work a trade for cast iron headers.
Looking for a good stock Chevy 1 bbl Intake Manifold for 250 Chevy I6 and Cast Iron dual outlet headers/manifold
I have the following parts to trade - 64, 65. (Will add to the list as I inventory.)
Prefer trade, Would trade all for both manifolds.
Heater box, engine bay side, no core but with lid and motor mount plate, motor works but bearing squeals
Heater plenum, cab side, with 3 speed coil
2 new LMC Lower Ball Joints
Good door glass - left and right
Good back glass - Small
I6 points dizzy + Coil and coil to motor bracket
64 C10 fender badge
2 hood hinges
3 speed shift rods (Column to trans) SM318 non granny three speed trans
Brake pedal with cross shaft and plastic bushings
1 white painted (light rust) headlight square trim piece
1 T3 headlight (High/Low beam, 7" Diameter)
All three of the 1964 chevy brass brake t-fittings, DS Front (1/4" lines in and out), PS Front (1/4 line in, 1/4 line out, 3/16 line out), DS Rear (brake hose in, 3/16 lines out) (Rear is 1964 specific, different fitting and mounting was used on the 1965 models - but the Fronts are the same both years.)
PM Please.
Sharps40 is offline
Old 02-02-2014, 07:39 AM   #2
Sharps40
Re: Want to Trade for I6 Intake Manifold
Originally Posted by Sharps40 View Post
Looking for a good Intake Manifold for 250 Chevy I6.
A stock Chevy 1 bbl intake log.
I have the following parts to trade - 64, 65. Will add to the list as I inventory.
Heater box, engine bay side, no core but with lid and motor mount plate, motor works but bearing squeels.
I6 points dizzy
PM Please.
Determined I can't use a Clifford as I'm not running enough carb/cam, etc.
Sharps40 is offline
Old 02-02-2014, 10:34 AM   #3
ScottH
ScottH's Avatar
PM sent
1963 C10 swb fleetside
1966 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline
Old 02-02-2014, 04:29 PM   #4
cru_zn_29
cru_zn_29's Avatar
PM sent
cru_zn_29 is offline
Old 02-03-2014, 09:17 AM   #5
Sharps40
Originally Posted by ScottH View Post
PM sent
responded
Sharps40 is offline
Old 02-03-2014, 09:18 AM   #6
Sharps40
Originally Posted by cru_zn_29 View Post
PM sent
responded
Sharps40 is offline
Old 02-03-2014, 12:20 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
PM sent.
TJ's Chevy is offline
Old 02-03-2014, 12:27 PM   #8
ScottH
ScottH's Avatar
Some pics of the one I have.....
ScottH is offline
Old 02-03-2014, 08:24 PM   #9
Sharps40
Sharps40 is offline
Closed Thread
