1968 k10 rear leaf spring shackle bushings needed!
Hey guys, do you know if anyone makes a shackle bushing for the rear of a 67-68 4x4 ?? I can't find anything. This truck I'm restoring it to original so I'm not switching brackets on the frame . Thanks!
Matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
Re: 1968 k10 rear leaf spring shackle bushings needed!
different than 60-66? lmc sells the 60-66.
1961 chevy K10 my build is------------61K10 build |
Try off road design in CO.
71 C-20 07 Magnum RT AWD |
not sure if 60-66 is the same or not, i know mine are roughly 2.5 length, 1.5 diameter.
I thought about buying some leaf spring bushings that same diameter and turning them down in a lathe to my length i need. Matt
![]() Join Date: Aug 2008
Are they bronze bushings or rubber? If LMC doesn't have them you might have to machine your own. But be aware they need holes and slots for grease distribution.
Also, on my 66 the original bronze bushings had been completely worn through and had also worn the steel of the shackle and hanger so they were no longer round. In this case a stock bushing would no longer work.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
