Old 01-03-2011, 10:39 AM   #1
jkade
jkade's Avatar
M1009 with LQ9
Getting closer... I hope to have it running by the weekend. I know there are other people out there that have questions about doing this in a 4x4 so let me know if you have any questions.
Motor is from a 02 Caddy, comp xr275hr-12 cam, ford 30lb car injectors, 98 fbody harness, using the flexplate that came on the motor with the gm spacer between the flexplate and the converter. The converter is a hughes gm25hd (2200-2500), running a np241 from a 91 burb with the vss. The motor mount adapters are from car shop inc and are the one for the 1" set back. The motor mounts are in the factory holes. I am using a cluster from a 91 burb, gas tank and sending unit are from a 91 burb with a 96 vortec pump. The fans are from late 90's early 00 ford windstar fan. The headers are Mac Mid Lengths for a 98-02 camaro/firebird.
This is my woods/hunting truck so I was not worried about clean and paint. If it was a show truck I would have painted the motor etc
Hopefully this will help others out. Let me know if you have any questions.
jkade is offline   Reply With Quote
