Old 02-17-2014, 09:54 AM   #1
K98AL
K98AL's Avatar
Stupid Belt Noise
I've got a 1962 235, and the belt noise is driving me nuts.
The Crank pulley looks a little wider than the water pump and alternator pulleys. (the belt is farther "down" into the crank pulley)
I can squirt a little belt dressing on and it gets silent (heaven!), but only for a minute. The alignment looks right, and the belt is tight. Is there an easy fix?
K98AL is offline   Reply With Quote
Old 02-17-2014, 11:46 AM   #2
firemanjimtfd
firemanjimtfd's Avatar
Re: Stupid Belt Noise
I have used a old trick of rubbing bar soap on the belt .
firemanjimtfd is offline   Reply With Quote
Old 02-17-2014, 12:02 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
I had the issue slightly when I had the 40+ year old belt still on....I got one of Napa's premium belts and even on cold mornings nothing squeaks. My pullleys are a little narrower I think.
Old 02-17-2014, 01:44 PM   #4
K98AL
K98AL's Avatar
I put a new, premium belt on - helped, but not 100%
I'll try the soap - thanks Jim.
Old 02-17-2014, 02:53 PM   #5
T and S
T and S's Avatar
Belt noise can also be caused by the pulleys being worn out. The belt will actually slip as it goes around the pulley no matter how tight the belt is.
T and S is offline   Reply With Quote
Old 02-17-2014, 04:22 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
It is likely the pulleys are not compatible. I no longer remember the angles, but the really wide original pulleys may have required a 40 or 45 degree side angle on the belt. I think the newer (thin) belts were pretty standard at 37 degrees (or something close to that). The only permanent cure may be replacing that lower pulley with one that matches the water pump and alternator.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-17-2014, 04:23 PM   #7
Sharps40
Same here....I've learned to love it...sounds like a gear drive cam shaft....increasing in pitch with rpm till eventually it blends in with the sound of a cinderblock wall being pushed thru a hurricane at 70 mph!
Check pully alignment....I tweaked my alternator position with shims and thinning of the bracket tab and eliminated a buncha that whine.
Sharps40 is offline   Reply With Quote
Old 02-17-2014, 07:45 PM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Make sure all the pulleys are lined up too.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-17-2014, 10:02 PM   #9
LVPhotos
LVPhotos's Avatar
Take the "Shine" out of the pulley with sandpaper or the like. Stop using belt dressing it just makes it slip more.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-18-2014, 08:58 AM   #10
K98AL
K98AL's Avatar
Thanks for all the advice!
