Old 01-16-2013, 01:15 AM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Need recommendation for adhesive to attach felt to A/C vent ball housing
I need to tighten up the A/C balls - can anyone recommend an adhesive to attach the felt? Couldn't find any recs on a forum search. Thanks, Pete
Old 01-16-2013, 01:44 AM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: Need recommendation for adhesive to attach felt to A/C vent ball housing
I just bought some new ac felts which came with adhesive back already on it. If you wanna use your originals I would probably use some 3M weatherstrip adhesive. It's lack a tacky yellowish adhesive
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 01-16-2013, 02:06 AM   #3
truckster
truckster's Avatar
^X2
3M Super Weatherstrip Adhesive is also available in black. It works well on weatherstrips, moldings, and gaskets. I'd bet it would work well on the felt, too.
truckster is offline   Reply With Quote
Old 01-16-2013, 09:39 AM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good deal guys -thanks! Where did you get the adhesive backed felt? I bought my fresh felt from a board vendor and it lacks the adhesive backing. Maybe backed felt is a better way to go...
Old 01-16-2013, 10:44 AM   #5
hfd410
hfd410's Avatar
mine was'nt adhesive backed so I sprayed em with super 77 adhesive. Worked great....
hfd410 is offline   Reply With Quote
Old 01-16-2013, 10:51 AM   #6
1972SUPERSB
I got mine from classic parts. The adhesive ones came with the diverted ball housing when I bought them. They sell the felt by itself also. You may wanna ask them if the ones by themself are adhesive backed.
Jeff
Old 01-16-2013, 11:36 AM   #7
midniteblues
midniteblues's Avatar
that is some good stuff there.
just tape up what you dont want coated and spray away
IT WONT COME OFF
if you dont want it too. any home depo,lowes,hardware store should have it. lil' pricey but you get pretty much in the can.
another option is the small can of contact cement it come with a small brush in it and if used right it wont come off either but i would recomend the first too as they dont have a tendincy too soak through
the weather strip stuff is really good(n probally less $) also they are all messy so be sure too tape up
word of warning if you go this rout do not get the cheaper spray glue it will fall off in the heat of the summer(see my awesome vinyl headliner in my pontiac)
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-16-2013, 09:14 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks again guys - all good suggestions. I have a can of Super 77 adhesive here that I'll try that first: it's leftover from my headliner install. It failed on that task. I had to go with the 3M weatherstrip adhesive in black to get the headliner attached to the roof.
Old 02-17-2013, 10:42 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Just a follow-up. The Super 77 worked fine. I applied it to the felt then draped that into the housing. Wes (Classic Heartbeat) says he doesn't use adhesive and the felts stay put. May try that next time. Thanks again, Pete
Old 03-05-2014, 05:17 PM   #10
Topfuelflat
Topfuelflat's Avatar
The ones from Classic parts don't come with adhesive, I cant imagine not having any on there but I've never tried it that way.
72low
Topfuelflat is offline   Reply With Quote
Old 03-05-2014, 05:25 PM   #11
DT1
DT1's Avatar
X2 on 3M 77 aerosol adhesive. 3M 99 aerosol is even stronger but you can't use it on Styrofoam but felt is OK. Both can be got a Home Depot.
DT1 is offline   Reply With Quote
Old 03-05-2014, 08:30 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The Super 77 is holding up so far - was a bit messy getting the felt in place and trying to keep it off the free edge of the felt...follow-up pic that shows the repro felt is lighter in color than OEM
Old 03-05-2014, 09:47 PM   #13
Topfuelflat
I sure liked dealing with Classic Parts- good prices fast shipping and their quality is supreme.
72low
Old 03-05-2014, 10:21 PM   #14
jocko
jocko's Avatar
Pete, I find it hard to believe your felts weren't already perfect. I could stare at that truck all day... Anyhoo - been a while since I bought these, but I could've sworn mine were adhesive backed. In fact, I think I bought them for an Impala, they had the same arrangement of felt+chrome ball. Pretty sure they were from either Impala Bob's or Year One - and they would fit these a/c vent holders as well, I'm almost certain. Anyway, glad they turned out good for you.
Old 03-05-2014, 10:39 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks! I can't wait for the weather to improve so I can drive on salt less roads. My felt came from Classic Heartbeat (thank you Wes) no adhesive but working well so far. I just saw a pair of NOS chrome vent balls fetch something like $265 or so on ebay.
