custom trailing arms ideas?
Been installing air ride in my truck for the past few weeks and got to the rear trailing arms and there shot beyond fixing. I dont really wanna spend $400-600 on a porterbuilt, cpp,... ect. set. I figured it would be much cheaper to make some and was wanting some input and possibly some pictures of some. Thanks!
Re: custom trailing arms ideas?
Any links on where I mighy be able to get some heim joints orb other helpful parts would be awesome too! Thanks again.
![]() Join Date: Oct 2012
search around www.pirate4x4.com its the oppisite end of the spectrum but there is still plenty of relevant info on making suspension links
![]() Join Date: Jan 2011
Look around your area for guys running circle track. I got a nice set of NASCAR truck arms for $80. Came off a pavement late model.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I used cpp box plate for the stockers and powdercoated. The with the truck going lower to correct angles and move axle back I went PorterBuilt with 1" drop built in.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
There is a "how to" thread here about making tubular trailing arms. Has links to the joints needed.
http://67-72chevytrucks.com/vboard/s....php?p=3805406
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
