Stylin
im switchin to the 100mph speedo
im switchin over the a 100mph speedometer from the older trucks, is there anything special i need to do? ive heard something bout a vss sensor but i have no clue what the hell it does lol. but i gotta put everything backtogether so i can get a loan which sucks lol. i dont mind the font for the time being as ill just print off a new label and put it on to match my new gauges that a bought...
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
there is no VSS as the speedometers are cable driven. shouldnt have to do anything but regear for the speedo.
You get what you pay for
![]() Join Date: Dec 1999
The VSS is a green box that was used for the cruise control. I'm not sure of the hookup on the 100 mph speedo. If you don't have cruise, don't worry about it.
As far as regearing, no need to. Nothing changes when changing speedos. Just hook it up and go.
Mike 1985 Chevy C-10 |
Stylin
i have cruise control but it throws its self wide open most of the time so i un hooked it
The VSS is the little green box with the optic cable that plugs into the back of the speedo. The speedo cable hooks up the same as on a 85 mph speedo.
www.73-87chevytrucks.com
As Mike said, it is just a simple replace. The connections are the same and the speedo ratio is the same. The ONLY things different is the font and you would need the VSS to use the cruise. Since you aren't, and are willing to overlook the fonts, it is a simple plug in.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
