Old 03-07-2014, 11:21 PM   #1
AusMarty
Turbo 350 problem
I have a turbo 350 trans which is now out of the truck, it was rebuilt from previous owner, the problem is when you put it into drive it would hesitate before it would engage in forward and reverse, Oil level was fine, I pulled it apart today and found everthing is in really good condition, the pump clutches seals all look fine which is a bit of a worry because I don't want to put it back in and have the same problem, could it be the torque converter doing this ? it looks like it has been replaced also, it has a number on it 47011 which I looked up, summit advertise it as Boss Hog night stalker, the truck has done 3500mls since rebuild, any Ideas ?
AusMarty is offline   Reply With Quote
Old 03-08-2014, 12:05 AM   #2
cableguy0
Re: Turbo 350 problem
A transmission slow to engage is either low pump pressure (bad pump) or lip seals in drums not sealing. Have you torn the unit completely down? By completely I mean tearing the drums themselves apart?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-08-2014, 12:14 AM   #3
AusMarty
Thanks for your reply, yes I have it fully stripped, pump looks fine, no damaged seals on the pistons
Old 03-08-2014, 10:29 AM   #4
bigmac73
bigmac73's Avatar
i bought a boss hog , in the past had problems with it not correctly working , not a fan , when i rebuilt my tranny last month i went back with a B/M holeshot (using them years ago) works perfect , I should have bought the B/M the first time Around , but tried to save money, I guess the lesson here is Stick with what has worked well in the past,
if you rebuild the tranny, ditch the boss hog POS
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 03-08-2014, 06:42 PM   #5
AusMarty
thanks for the reply Bigmac, what problems did you have with the Boss hog converter ?
Old 03-08-2014, 07:09 PM   #6
cableguy0
I have seen people have both real good and real bad luck with both the boss hog and B&M converters. I personally wouldn't put any of the garbage converters B&M sells in anything I run. B&M has been living on a name for a very long time. If you want quality look at Ati,Tci,hughes,yank etc etc. You definitely get what you pay for. In my experience I couldn't talk down about boss hog without mentioning B&M in the same sentence.
Old 03-08-2014, 07:27 PM   #7
AusMarty
So do you guys think the torque converter could cause this problem ?, can it be tested ?
Old 03-08-2014, 08:05 PM   #8
cableguy0
Torque converters are sort of a voodoo art. For example You cant buy a converter off the shelf that will be exactly 2000 stall. It would be an 18-2200rpm stall. So many factors including the quality of parts and workmanship affect a torque converter they are tough to nail down. With what your describing it sounds like just a worn transmission. Have your air tested the drums? What is your clutch clearance within the drums? Clearance too loose could lead to a delay in actual gear apply because it takes too much fluid to fill the drum. Did you pull the pump apart? Also did you check line pressure before you pulled the unit apart?
Old 03-08-2014, 08:16 PM   #9
AusMarty
The trans only has about 3500 miles on it,the trans is fully stripped, everything looks new, pump is nice, the frictions have very little wear, I will check the clearances, the problem was intermittant, unfortunatley I didn't do a line pressure test before it was removed
Old 03-08-2014, 08:22 PM   #10
cableguy0
A tiny bit of trash in the valve body could also cause your issue. Its extremely difficult to nail down a problem like this after the fact especially over the internet. Hopefully Clinebarger will chine in here and throw out some ideas. Hes got a lot more trans experience than I do.
Old 03-08-2014, 08:40 PM   #11
AusMarty
Thanks Cableguy, I know what you mean it's a bit hard to nail down, I guess if I can find out what areas to look at for the specific problem then I can pay particular attention to them
Old 03-12-2014, 05:02 PM   #12
jfortvalley
when it hesitates is it first thing in the morning then does fine until the next morning
jfortvalley is offline   Reply With Quote
Old 03-12-2014, 06:17 PM   #13
litew8
litew8's Avatar
I had the same problem. Hesitate when put into reverse and engage hard after. Had it rebuilt and different torque convert, problem is gone - if that helps isolate your trouble.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 03-12-2014, 08:19 PM   #14
clinebarger
You doing a good job, I would like to know when it does it? Like Fortvalley stated...If just after it sits...Converter drain back...Check Stator support bushings.
clinebarger is offline   Reply With Quote
