Old 03-08-2014, 02:49 AM   #1
MikeyInMarin
Car Cover + Rain = Doughboy pool in bed
Hi,
I think this is my first post, but I've been a member since I got the truck in 2011.
Anyway, I can't park 2 cars in my 2-car garage for the usual reasons, so the truck stays outdoors. I am on my second car cover (first one fell apart) and have the same problem as with the first. When it rains the cover catches the water, drags the cover into the bed, and makes a doughboy
I put plastic 6 grommets in the first cover to let it drain into the bed. That worked (no more doughboy), but it weakened the cover (it started to tear).
I don't want to do that with the new one (the manufacturer says it will void the 5-yr warranty). They said to put plywood over the bed. I just had the truck painted last year and don't want the plywood to scratch/wear the top of the bed.
I can't be the first to have this problem. What did you do?
MikeyInMarin is offline   Reply With Quote
Old 03-08-2014, 03:36 AM   #2
OARNGESI
OARNGESI's Avatar
Re: Car Cover + Rain = Doughboy pool in bed
can you put something in the center of the bed under the cover that's higher than the bedsides so when it rains it runs off before it ever pools up. kind of like where it snows a lot they build houses with really high pitched roofs.
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-08-2014, 07:59 AM   #3
acemang
acemang's Avatar
Only thing i know of is people using tonneau covers.
acemang is offline   Reply With Quote
Old 03-08-2014, 08:15 AM   #4
serge
serge's Avatar
Something like a small round plastic picnic table.
serge is offline   Reply With Quote
Old 03-08-2014, 09:12 AM   #5
OldCreek
OldCreek's Avatar
Cut some slits in the cover and SEW the edges like a button hole.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-08-2014, 01:26 PM   #6
MikeyInMarin
Somebody at work suggested putting a pole in the middle. The problem is when the wind blows hard, it could put too much stress on the cover; the cover blows off often (even strapped down, it becomes a girdle behind the cab).
Hmm, maybe a small plastic table would work though. It's also easy to try.
69 GMC 1/2 ton long-bed, 350 TH400
Old 03-08-2014, 01:27 PM   #7
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
You could build a small platform in the bed, say a 4x8 sheet of plywood made into a table about 6" taller than the bedsides. You wouldn't have anything touching the paint and no puddle.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 03-08-2014, 01:32 PM   #8
kentucky_smith
Get one of those big blow up balloons they use for pool covers
kentucky_smith is offline   Reply With Quote
Old 03-08-2014, 02:00 PM   #9
Hawghauler
Hawghauler's Avatar
get some pvc pipe and fittings and make a tent frame. costs less than $20
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 03-08-2014, 04:24 PM   #10
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I would use plywood or OSB across the top of the bedsides. Just use something to stand it off of the bedsides. Maybe something in the stake holes, or use some truck cap foam between the plywood and bed rail. Maybe even large rubber bumper. This way you don't have to cut your cover… You don't have to worry about any areas for the cover to sag into when it rains.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-08-2014, 05:06 PM   #11
tlcrz1972
tlcrz1972's Avatar
Take a couple of automotive inner tubes, air them up and stack them in the middle of the bed under the cover higher than the bed sides.
A couple of pool/beach balls would do it too.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
Old 03-08-2014, 06:43 PM   #12
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I don't know one of these would be in your budget but I've seen a few posts on here with board members talking about these and and doing a little net surfing will get competitive pricing. If you are planning on keeping your truck long term I'd protect the box, as water causes rust and rust never sleeps.....
http://extang.com
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-08-2014, 06:55 PM   #13
litew8
litew8's Avatar
Stand a 2x4 up in the middle with a piece of thick rubber sitting on the top end. Tarp over the top.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 03-08-2014, 07:14 PM   #14
seamus2154
I would say a large beach ball or small plastic pvc table would work and the wind wouldn't matter. I also would bunji cord the back of the cover taunt towards the back and the water will run off.
seamus2154 is offline   Reply With Quote
Old 03-08-2014, 07:47 PM   #15
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Car Cover + Rain = Doughboy pool in bed
2 Tractor tire inner tubes with big beach ball dead center of bed. Should be enought to make the water run off and not hurt the truck. Best thing would be a hard bed cover though in the long run. Car cover will scratch the paint over time if left out side all the time. Sooner are later.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-08-2014, 09:40 PM   #16
Gokart Mozart
Lower the tailgate. If the cover tears, it has a 5 year warranty.
Gokart Mozart is offline   Reply With Quote
Old 03-10-2014, 10:54 PM   #17
MikeyInMarin
Wow, thanks much for all the creative ideas! I really never would have thought of them.
Since I want a solution that's small so I can keep it in the bed normally, I might do a variation on derotoreut's idea (stakes & plywood), but with a rope perimeter in eyelets-on-stakes instead of plywood.
Thanks all!
Old 03-11-2014, 12:25 AM   #18
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Thanks all!
Hey, Mikey.
Marin native and expat, here. We're up here in the mountains a few hundred miles from you now.
I struggled with this one for a couple of reasons and over more than a few seasons. I know a tonneau isn't for everyone.
In fact, it's not for me much of the time.
I have heavier snow than in this pic a couple of times a year or more. I also just had the paint work done...and put in my
version of a wood over steel bed floor. Not everyone's cup-of-tea, I know. It was a temp thing that I like enough to keep.
As of now, I don't drive RAT in the rain. I figure that'll change after the $ting of the paint cost wears off.
I, too, have to park outside most of the time.
I had this tonneau from my last short bed (72). It only cost a little more than a hundred bucks. The tonneau cover fends off all
rain and snow, and keeps the groceries and other purchases out of the hands of hungry parking lot gremlins. I usually pull it off
(takes 15 minutes tops for the whole thing, rails and all) for spring and summer.
If it's on and I have to haul something in the bed, I can roll it up like a cowboy's bed-roll.
Like I say, not for everyone. But it works. And aesthetics aside, it would work well for your purpose .
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 03-11-2014, 05:28 PM   #19
Gokart Mozart
http://www.camping-gear-outlet.com/c...ear-51388.html
Price: $129.99
Pool won't become as deep! Get 2 and there'll be no place for water!!
Old 03-12-2014, 01:54 AM   #20
brad_man_72
the boat guy
brad_man_72's Avatar
Park the front wheels on some ramps, that way the water will drain out the back with the gate down.
If your cover is blowing in the wind it is probably doing more harm than good anyways.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-12-2014, 02:39 AM   #21
BBrendal
Recalculating.....
BBrendal's Avatar
Two plastic chairs put back to back in the bed will be high enough to let h2o roll off.
Brian - (BBrendal)
1969 Chevy Camaro Z28
1972 Chevy Blazer CST
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline   Reply With Quote
Old 03-12-2014, 08:19 AM   #22
Anything you put under the cover in the bed,other than completely covered with plywood,will still allow water to pool at the lower points. With no drainage the pool gets bigger and heavier and the tarp gets pulled down lower. My truck isn't a show queen,or even restored,but I do want to preserve it while it has no garage to sit in. My concerns are leaves in fall and other tree debris as much as rain water. I only cover the cab and just make sure the drain holes in the front of the bed are clear,since I park it with the front lower. Parking with rear lower is best for bed and roof gutter drainage. But if your bed is painted good then I wouldn't be concerned as long as the water isn't held from draining. Driving an outside vehicle is also important to drying out moisture held within the body
Old 03-12-2014, 10:19 AM   #23
Pargolf
Pargolf's Avatar
Make a sawhorse that is the length of the bed?
1967 GMC SWB SS
2000 BMW 328i
2001 Jeep Grand Cherokee Ltd
2011 Acura MDX
Pargolf is offline   Reply With Quote
Old 03-12-2014, 10:24 AM   #24
Gumby
Gumby's Avatar
IVe fought that forever, nothing but a bed full of junk, sort of stops it, it still finds places to sag, hard cover is the only sure fire cure.
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 03-12-2014, 10:35 PM   #25
swamp rat
swamp rat's Avatar
Make a saw horse out of 2X4'a and the store bought brackets, make it as long as your bed, then buy the adjustable tarp tie down clamps you can get from a hardware store, attach them to where you can string a rope thru them to make the cover tight.
If you have steak pockets you can bend smaller diameter PVC pipe to make 3 hoops about 3' tall in the center.
Or do what i do, buy the 20'X10' car covers and separate enclosure kit, just be sure to lash them down if the wind starts to blow. Oh, i got the ones offered by Amazon Prime not from Northern tool.
Amazon.com: Key Parts 25757 10 X 20 Canopy 6-Leg:... Amazon.com: Key Parts 25757 10 X 20 Canopy 6-Leg:...
Amazon.com: Key Parts 25775 Enclosure Kit 10X20:... Amazon.com: Key Parts 25775 Enclosure Kit 10X20:...
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
