Old 09-01-2008, 03:09 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
vortec head conversion, few questions
my 1406 edelbrock performer carb had to have an adapter to work with my old stock intake, now naturally the adapter isn’t needed, the bolt holes do line up on the new vortec intake, can i just go get a new gasket and call it good? or do i need a plate for some reason.
Secondly, the water temp sending unit is a bit smaller. i just got one for a 97 chevy and it fits ok, shouldn’t have any troubles with the gauge as far as i figure, but perhaps one of you have ran into that before. also, any reason that i can just snip the wire and put on a normal wire connection is there?
i know these are some obvious questions, but im trying to head off troubles before i have them and it kills time when i have help working on the truck.
link to the build post
http://67-72chevytrucks.com/vboard/s...d.php?t=304830
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 09-01-2008, 03:51 PM   #2
Irishpilot
Re: vortec head conversion, few questions
Get a new gasket and you are good to go. As far as the temp sensor, I just routed it up to the front of the manifold since it is the same size as the senor hole from the stock heads. As far as snipping the wire and using a connector, there shouldn't be any issues.
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
Old 09-01-2008, 04:05 PM   #3
mtdave2
mtdave2's Avatar
well the size is differant. the new one is 3/8. the old is 3/4? still shouldnt matter...
69 k10 Suburban
Old 09-01-2008, 07:31 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
I ran into the same issue a couple of weeks ago when putting a 97 vortec engine w/ Vortec to TBI Crusader intake manifold into a 1993 GMC. K20Go to a local hardware store or "Mom and Pop" auto parts that sells brass adapters and get a brass bushing to adapt the 3/8" to 3/4". Pick up some teflon tape to wrap the threads before you screw it in. (Be sure to wrap it in the direction that it screw in so that the teflon tape does not wad up when you screw it in.
WIDESIDE72 is offline   Reply With Quote
Old 09-01-2008, 11:04 PM   #5
jkaylor68gmc
jkaylor68gmc's Avatar
awesome, I am doing the same swap this upcoming weekend!
I got the HVH aluminum double humps with the vortec style mounting.
can't wait, How does yours run?
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 09-01-2008, 11:28 PM   #6
mtdave2
mtdave2's Avatar
i havent got it in the truck yet.. maybe this weekend it will be running.
i did find a 3/8 plug, and a sending unit from a 97 chevy. so i should be ok
69 k10 Suburban
Old 09-01-2008, 11:38 PM   #7
jkaylor68gmc
cool, I though, oh yeah, it will be easy, dang, I have had to buy everything to make the swap, it is crazy
1962 swb fleetside
Old 09-02-2008, 11:38 AM   #8
cameeks
Long Fleet Club
cameeks's Avatar
Originally Posted by WIDESIDE72 View Post
......... get a brass bushing to adapt the 3/8" to 3/4".
It would be 3/8" to 1/2"
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 09-02-2008, 02:59 PM   #9
70rs/ss
70rs/ss's Avatar
I read somewhere that the newer senders do not sinc up with the old guages, it fits the hole, but the reading will not be accurate. You can adapt the old style to the smaller vortec hole or open the hole up to accept the early style, or worst case senario, put the early style sender into the intake as opposed to the head.
70rs/ss is offline   Reply With Quote
Old 09-02-2008, 08:42 PM   #10
mtdave2
mtdave2's Avatar
hum that would suck.. i know others on this board have done this conversion, i wish they would help me out here!
another issue i have just found is my top a/c bracket. the end that connects to the intake bolt is angled, as is the stock intake....vortec is flat! so, looks like ill have to do some heating and bending ,,unless someone has done this and can give me another idea!
ugh, this was my fear when i was deciding to go with the vortec or not, i hate loosing my stock stuff.. might loose my long oil filler too....
69 k10 Suburban
Old 09-02-2008, 09:53 PM   #11
BP68
BP68's Avatar
How about a pic of that a/c bracket you mentioned?
If you a referring to the long oil filler tube in the valve cover, some trucks/suvs had a long plastic fill tube that screws in the valve cover and is topped with a screw on cap. I beleive my 98 had that setup.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 09-02-2008, 10:07 PM   #12
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
The sending unit for a late model will not work properly . I ended up with my stock sending unit in the thermostat housing . You can buy a t-stat housing at the parts store that the factory sending unit will screw in to. Otherwise you run an aftermarket gauge set up . I just went through this with my Dart heads . Hope this helps . Bob
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 09-02-2008, 10:27 PM   #13
Jtrux
I'm a poor spectator
Jtrux's Avatar
You need to check the ohms of resistance. It's probably different.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-03-2008, 12:42 AM   #14
mtdave2
mtdave2's Avatar
see the box shape metal? on the stock intake, that is angled at a 45.
69 k10 Suburban
Old 09-03-2008, 01:19 PM   #15
mtdave2
mtdave2's Avatar
i have found several issues, everyone of them are related to the differance in the head angle.
the long oil flller tube (bend end and drilled new hole)
spark plug wire holdrers. (was able to bend them as well)
both the a/c brackes, one i hope to heat and bend, the other (pict below) ill have to build a custom bracket.
no hole for the rear bolt of the mount!!!
and the last one, one i have mentioned before, i took your advice, and got a 3/8 to 1/2 reducer and used my orginal temp sensor. i hope there are not cleance issues.
things are starting to come together...
69 k10 Suburban
Old 09-03-2008, 01:27 PM   #16
mtdave2
mtdave2's Avatar
oh ya, an no comments on the mess in the garage, its driving me crazy!!
69 k10 Suburban
Old 09-03-2008, 02:42 PM   #17
jkaylor68gmc
Well I went to the dyno last night so I am going to begin my vortec swap also. You gave me a good idea, I guess I could cut my brackets and just reshape them to fit the flat mounted vortec manifold.
1962 swb fleetside
Old 09-03-2008, 04:15 PM   #18
ostncoln
ostncoln's Avatar
not to change the subject but, is that a aluminum intake painted orange? if so it looks good. i have been thinking about doing that but i cant decide how it would look.
1971 C-10 Project
350/400
5/7 drop
My Slow Build Thread
ostncoln is offline   Reply With Quote
Old 09-03-2008, 04:20 PM   #19
Ole Blue 68
Ole Blue 68's Avatar
That's a mess??
You should see my garage.
Ole Blue 68 is offline   Reply With Quote
Old 09-03-2008, 04:22 PM   #20
Jtrux
Jtrux's Avatar
Yep.
Old 09-04-2008, 12:40 AM   #21
mtdave2
mtdave2's Avatar
ya, i wasnt sure i wanted to paint it, but im glad i did. i think it looks great!
69 k10 Suburban
Old 09-04-2008, 04:24 AM   #22
cameeks
Long Fleet Club
cameeks's Avatar
......and the last one, one i have mentioned before, i took your advice, and got a 3/8 to 1/2 reducer and used my orginal temp sensor. i hope there are not cleance issues.....
Hold the header up to it and see if it clears. My Headman headers wouldnt.
Chris Meeks
Old 09-04-2008, 12:53 PM   #23
70rs/ss
70rs/ss's Avatar
I wonder if that is going to clear, but also how acurate it'll be? The intake doesn't read too great, but may be better than the sensor where it is? Try and see, it can always be swapped later. The ac part should be pretty easy, just cut the bracket and weld it up to fit the front hole and runa piece of metal back to the rear holes and use that bolt. I wouldn't reconfigure the whole brack et with new, just cut and paste (weld!) Looks good and I am positive you'll be happy with the heads.
Old 09-04-2008, 07:24 PM   #24
Jtrux
Jtrux's Avatar
I'm just bumping this for Dave when he gets around to posting pics of the mods he had to do to the brackets, heat..bend, heat..bend, etc. etc.
Old 09-04-2008, 11:37 PM   #25
ERASER5
ERASER5's Avatar
mtdave2, Look up the Low Buck build in the projects section. When the LS5.3 was put in, Kevin had the same issue. He found an adaptor that worked.
Other wise, if you have access to a lathe, there enough brass on your sender to cut it down to the proper thread.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
