Old 04-05-2014, 05:26 PM   #1
Bullett
Inner door panel fastener type
Need to take the inner door panel off my 62' in order to see why my window won't roll up or down. I have many tools in my tool box but nothing like the tool needed. What do they call the type of screws used for the door panel. I am assuming they are stock GM fasteners. I can take a pic if needed. Thanks...Bullett
Bullett is offline   Reply With Quote
Old 04-05-2014, 06:36 PM   #2
donthekawguy
donthekawguy's Avatar
Re: Inner door panel fastener type
You should be able to use a phillips screwdriver. If they are stuck you can use a impact driver. If they are different send a pic so we can see what you have.
66 shorty
donthekawguy is offline   Reply With Quote
Old 04-05-2014, 07:55 PM   #3
LVPhotos
LVPhotos's Avatar
Clutch Head screws. Only place I found the drivers was TUCKERS. LMC truck has them #38-1259 or sockets 38-1257
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-05-2014, 09:19 PM   #4
Bullett
I looked at clutch head screws on ebay, That doesn't appear to match up with what I have. I took a couple pics, which aren't very clear but hopefully clear enough.
Old 04-05-2014, 09:37 PM   #5
ray_mcavoy
Those look like tamper-proof torx ... definitely not original to this generation of truck.
Screwdrivers / bits are avilable to remove them. They look like a regular torx but have a hollow tip to clear the raised pin in the center of the screw heads.
ray_mcavoy is online now   Reply With Quote
Old 04-05-2014, 09:43 PM   #6
LVPhotos
LVPhotos's Avatar
The bits that came with cheap screwdriver have that hollow star /torx. Parts store should have those.
Old 04-05-2014, 09:48 PM   #7
Bullett
O.k., I thought it looked like a Torx type head but never seen such with a protrusion in the center. I will head to the tool store in the morning to see if I can find the correct tool. Why the heck would someone use these on an interior door panel? I guess as long as you have the correct tool, I guess they are probably fine.
Old 04-05-2014, 10:50 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Whoever put them in probably worked in a maintenance department where he obtained a surplus of them for free. I can't imagine why anyone would want those on a privately owned truck.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-06-2014, 09:55 AM   #9
corvettejim1968
corvettejim1968's Avatar
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 04-06-2014, 11:41 AM   #10
Bullett
Just went to Auto Zone and found just what I needed. Dang, I have been turnin' wrenches a long time and never happened to come across these.
Thanks for the replies and pics. Much appreciated.
Old 04-06-2014, 10:03 PM   #11
luvbowties
luvbowties's Avatar
Wink Re: Inner door panel fastener type
Next time u visit an Interstate rest room, notice the screws holding the stall-panels together--that's what they use, as those panels are nice sheets of stainless(Some could be aluminum, but still nice, and otherwise tempting to thieves.) Those things stink!
Sam
luvbowties is offline   Reply With Quote
