Old 08-01-2014, 01:29 AM   #1
JacobSchni
JacobSchni's Avatar
bed mounting bolts question
Anyone know where to find stainless steel bed to frame mounting bolts for a fleet side long bed. I can only find steel ones. If you have any tips that i could use to just prevent my bolt from rusting ill just get the steel. Also on 4 of the 8 bolts the last owner spun out the square hole that holds the bolt in place. how would you fix this. the only ways i can think of is buying a washer with the square hole and welding it into the spot.
JacobSchni is offline   Reply With Quote
