Old 04-10-2014, 03:02 AM   #1
Slammed84
Slammed84's Avatar
Electric Fan Wiring... Thoughts... Opinions
Getting close to being able to mount the radiator support. Need to run the wiring first for my electric fan. I don't have the option of using the temp switch because someone glued in the plug on the intake.
Probably just run it through a switch under the dash.
Need thoughts about using a relay or if it needs a fuse, or if I can just wire the power through the switch and turn it on as needed.
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
