Old 04-17-2014, 11:52 PM   #1
hardwaycooke
hardwaycooke's Avatar
want upgraded master cylinder...any dealers...or help??
I have a 71 c10 lb, disc on front drum on back...manual brakes. I do not want to upgrade to pb, I just want to upgrade the ms and components to something nicer looking..any advice is appreciated. Thanks
hardwaycooke is offline   Reply With Quote
Old 04-18-2014, 01:02 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: want upgraded master cylinder...any dealers...or help??
This is just one vendor on E-Bay
........http://stores.ebay.com/whiteperforma...=p4634.c0.m322
Don't forget to get new front brake hoses for disc brakes and you will need a new proportioning valve for disc/drum brakes, or disc/disc as the case may be.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-18-2014, 07:13 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
A good quality, budget minded option is to use one from a mid 80's C10 truck.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-18-2014, 10:58 AM   #4
mgchevyparts
mgchevyparts's Avatar
"Nicer looking" is quite subjective. Just make certain it is a 1" bore with a deep hole in the rear cup for manual brakes. Wilwood would be an option in my mind, although I use the 67-76 Corvette cast iron master.
Stay away from all those cheap Chinese masters-chrome alum, ports on both sides etc.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 04-18-2014, 11:11 AM   #5
leddzepp
Moderator
leddzepp's Avatar
Clean off your existing one and use some cast-iron finish paint on it. It will look brand new and no need to replace a part that still works and bleed your brakes. If you want some "bling" there are a lot of vendors on ebay as stated above.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
