sway bar ?
While I was at the wrecking yard the other day, I was pulling the rotors off of a 75 for my truck and noticed there was a front sway bar on the truck. Would that bar work on my 66? I should have pulled it but by the time I got what I needed I was grumpy and hot so I left it.
66 shorty ![]() |
Re: sway bar ?
You may have to drill holes in the lower a arms to mount it, but it should work barring previous damage. Check for heavy rust and make sure it is straight. Last thing you want is to mess up alignment due to bent sway bars
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
One foot in front of the other
![]() Join Date: Aug 2008
Re: sway bar ?
There is good info abou this in the FAQ section
Re: sway bar ?
My arms already have the holes which is a good thing. The truck wasn't wrecked I guess it just gave up so the scrapped it. It looked really clean on the underside. I just need to find out how it bolts to the frame now. On the 75 it has a bracket that is either welded or bolted onto the bottom of the frame the the bar mounts to. My truck doesn't have that bracket and I don't know if I even need it. I'll have to go back next week and check it out.
66 shorty ![]() |
Re: sway bar ?
OK got it figured out. Had to dig around in the search section for a couple hours but found the thread. I needed the lowered truck brackets. ECE wants $19 for the brackets and $19 for shipping!
66 shorty ![]() |
#6 | |
![]() Quote:
a couple of hours? ya coulda just went in the FAQ as someone suggested(up top in your own thread here) to the suspension section... more than one thread there with sway bar information. Well, we can lead a horse to water... -W |
Re: sway bar ?
Sorry - no matches. Please try some different terms. in donthekawguys defense thats pretty much all i can ever find searching the FAQs
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
#8 | |
Re: sway bar ?
66 shorty ![]() |
Re: sway bar ?
Here is links to two very good threads about swaybars:
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338 http://67-72chevytrucks.com/vboard/s...d.php?t=517255 When using FAQs you dont really have to do a search. Go to forums>1960-1966 Message Board>60-66 FAQ Index and then scrollaway until you find the blue link. Hope that helps. We want pics after install. |
Re: sway bar ?
** My truck is going to handle like a Vette!**
. Well Not quite like a vette But it is a very good upgrade . ![]()
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
#11 | |
![]() Quote:
![]() -W |
Re: sway bar ?
I shoulda went to the suspension area. I was just going to the FAQ at the top of the page.
66 shorty ![]() |
Re: sway bar ?
Those are the mounts I ordered. I got them at CPP. I'll take pics for sure. I should be getting my LCA's Mon. or Tues. from powdercoaters and start putting this thing back together.
66 shorty ![]() |
![]() Join Date: Jun 2010
Re: sway bar ?
We just grabbed a mid 80's 1 ton dually Chevy swaybar and all brackets out of the junkyard, trimmed the brackets bit and welded them in where they fit best on the frame, LCA brackets were a bolt on...$20 for the bar and less for new bushings
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
#15 |
Re: sway bar ?
I did the install awhile back and can definetly tell the difference.
