rear end hanging from shocks
will it break the shocks? I have jack stands under the frame now and no wheels on so the rear end is hanging from the leaf springs. (just put it back in today).
The shocks wont fit unless I jack up the rearend a little. But if I release the jack the weight of the whole rear end is hanging from the shocks. is that a problem? what happens when you lauch over a train track and get airborne? rear end would be hanging from the shocks at that point as well right ![]() ![]() ![]() |
Re: rear end hanging from shocks
The suspension will bottom out before the correct shocks are fully extended.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Cluster King
![]() Join Date: Nov 2012
If that is a concern, you can use limiting straps like off road trucks use.
You can buy them in any length you need http://www.quadratec.com/products/16...FagWMgodVDgAKQ
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
"What happens when you lauch over a train track and get airborne?"
The shocks will top possibly damaging the internal valving, limiting straps may work but its a band-aid approach, finding proper length shocks would be better, they should extend about an inch further than the mounts when hanging by the springs and the body small enough to allow the shocks to compress to about 1/2" shorter than the shock mounts when fully compressed.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#5 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
Not a good description but hopefully gets my point across. I understand we're probably talking about a 2WD truck, but some of us have been known to offroad with a 2WD. ![]()
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
so the answer is: no don't let it hang from the shocks while putting it back together in the shop? Im not going to be 4wheeling. Just a dumb joke at 3am.
Cars & light trucks with coil springs have been hanging from the shocks for many years. It doesn't seem good but I have never seen it hurt the shocks.
