![]() Join Date: Dec 2008
LS Swap lower radiator hose number
I found gates number 21718 to fit perfect if the two smaller diameter 90 degree ells are cut off. This hose has the correct 1 3/4 size for the radiator connection and the correct 1 1/2 size for the ls waterpump. I am using a new 4 row replacement radiator for the 68 c10. It may be of importance to know it is 14.25" from back of core support to front of air inlet on intake. This will tell you how far forward the engine is. Maybe this info will help someone.
Re: LS Swap lower radiator hose number
I know Im a bit late to this post. I bought a aftermarket radiator and having a hell of time finding a lower radiator hose that fits right. There any chance you can post pics?
I'm interested in this too. I looked up the part number and this is what came up:
UPC: 72053060270 Centerline Length (In): 28-1/8 Inch Inside Diameter 1 (In): 1-1/2 Inch Inside Diameter 2 (In): 1-3/4 Inch
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
