disc brakes
I was wondering if it would be possible to use 1 ton dully rotors on 71 1/2 spindles?
thanks |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: disc brakes
no.
Re: disc brakes
whats the difference in them?
Re: disc brakes
Nothings the same. Just buy the correct rotors, readily available.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
Re: disc brakes
Dually rotor needs the correct year C30 spindle.
The C30 spindle needs a different upper and lower balljoint, a different outer tie rod and a different lower control arm with a larger hole to accept the c20/c30 balljoint. Different bearings. Different caliper. Everything.
