Old 06-10-2014, 07:21 PM   #1
MountainGoat1966
Kick panel vent help needed
The passenger side kick panel vent on my '84 K10 (with a/c) decided it wanted to fail, and in the winter I get a SERIOUS cold air leak.
I don't have the shop manual for it and am having trouble figuring out what parts I will need to buy and how to put it back together.
Does anybody have the service info and pix ??
Many thanks !!!
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 06-10-2014, 08:24 PM   #2
MountainGoat1966
Re: Kick panel vent help needed
I remember when I removed the baffle thingy a long time ago, there was a coil spring inside of it that had fallen off from somewhere, I can't figure out where it went.
Old 06-10-2014, 08:47 PM   #3
tucsonjwt
I think the LMC catalog has a good graphic on how it goes together. Also, I think there is at least one vacuum actuator involved, along with a link and maybe a tension spring.
tucsonjwt is offline   Reply With Quote
Old 06-10-2014, 09:36 PM   #4
MountainGoat1966
I looked at LMC and their pic doesn't show the vacuum actuator thingy, or the spring. In fact, the pic really doesn't tell me much. That's why I am hoping to find somebody with the shop manual that shows/explains things.
I did learn on another site I was on that if the cup shaped baffle isn't there and screwed tight, the seal will leak. I removed that baffle a while back (and it grew legs and disappeared) but I do remember the spring falling out onto the floor.
I had a bad cold air leak even before I removed that baffle.
Old 06-12-2014, 02:21 AM   #5
chengny
chengny's Avatar
Here is the GM dwg and parts list:
A clearer dwg:
chengny is offline   Reply With Quote
Old 06-16-2014, 09:22 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
some i got,check that the plenum valve and the side shroud are connected
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
