![]() Join Date: Nov 2013
Wiring question
Been through the threads and.....
1) HEI wire to the ignition unfused on the fuseblock. 2) Have electric choke and I should add a 10 amp inline fuse and connect to other ignition unfused terminal in fuseblock 3) when I add tach, should I tap into ignition unfused as well, say piggyback with choke wire? |
Re: Wiring question
anyone?
Re: Wiring question
That's one way to do it I suppose. I purchased some packard 56 terminals from Napa and ran one of my wires through the original harness. If you look in your firewall wire gutter there should be a terminated wire sitting up there unused. That's the wire I used for choke.
#4 | |
Re: Wiring question
Re: Wiring question
If You mean just it's power wire then yes you can go to any keyed power source. I'm sure your aware the other goes to the distributor.
