Old 07-06-2014, 12:15 PM   #1
Ricks1971
Ricks1971's Avatar
trailing arms u bolts?
Where can you but new trailing arm u bolts for a C10/ thanks Rick
Ricks1971 is offline   Reply With Quote
Old 07-06-2014, 12:28 PM   #2
72tutone
Re: trailing arms u bolts?
Early classic sells them. If not you can check a tractor supply store.
72tutone is offline   Reply With Quote
Old 07-06-2014, 04:11 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My son took my old one to a big truck repair facility, and they bent me a new pair from good stuff...and furnished the washers and nuts. Cost me less than $15.
Member Nr. 2770
Old 07-06-2014, 04:38 PM   #4
72bowtiestepper
I got mine from Classic Parts of America 816-741-8029. They are the correct diameter and length....fit perfect.
72bowtiestepper is offline   Reply With Quote
Old 07-06-2014, 09:47 PM   #5
Ricks1971
Ricks1971's Avatar
thanks guys
Old 07-07-2014, 10:37 AM   #6
Fitz
Anywhere BUT LMC! When I changed mine I bought the new ones there. Those nuts get torqued between 180 and 250 ft lbs according to the factory assembly manual. LMC sent grade three nuts with half the grip length of the originals. The threads stripped at 130 ft-lbs. Last time I will ever buy from them.
Fitz is offline   Reply With Quote
Old 07-07-2014, 12:12 PM   #7
Procurement_man
Procurement_man's Avatar
That's what I did and about the same price make them while you wait.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel
Procurement_man is offline   Reply With Quote
