Old 05-20-2014, 06:31 PM   #1
suburban99
suburban99's Avatar
Is there a patch panel for the Inside roof on a '62?
Hey all just wondering if there is a patch panel available for the inside roof panel along the windshield? I have found the ones for the outside but none for the inside.
suburban99 is offline   Reply With Quote
Old 05-20-2014, 10:31 PM   #2
ls60apache
Re: Is there a patch panel for the Inside roof on a '62?
I see u need the outer also ,which they do repop ,but no on the inner roof section you will have to hunt down a donor like I did or fab it yourself. goodluck!
ls60apache is offline   Reply With Quote
Old 05-21-2014, 05:39 AM   #3
63sbssbbw
UCA63
63sbssbbw's Avatar
Funny how they only make the outer. (Usually) when the outer's gone, so is the inner.
I managed a donor with totally toasted floors.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 07-07-2014, 01:57 AM   #4
suburban99
suburban99's Avatar
Removed outer panel and now have inside one to deal with. I am thinking about patching the inside roof panel with some fibreglass as i can access it now. Then attaching the outside panel and then filling inside the cab with long strand filler.
Or welding a piece on the inside of the roof panel and filling after...I am concerned about warping the inside roof panel and think fibreglass will work just as good.
Old 07-07-2014, 09:48 PM   #5
lobuck64
i did fiberglass on my 64 worked out good
lobuck64 is offline   Reply With Quote
Old 07-10-2014, 01:00 AM   #6
lowlife4life
lowlife4life's Avatar
Are the inner roof panels the same as 64-66?
lowlife4life is offline   Reply With Quote
Old 07-10-2014, 01:06 AM   #7
suburban99
suburban99's Avatar
I don't think so as the windshield is different.
I think fiberglass is the way to go.
Old 07-10-2014, 07:24 PM   #8
ls60apache
they are until u get to the A pillar I used a donor section from a 64-66 on my 60. the outer section is the same for 60-66 and its welded to the inner.
