Old 03-12-2015, 08:25 PM   #1
67gmcss2
Engine dies
My truck dies when I unhook the battery. it's 67 gmc if that helps. have had the alternator checked at two places- autozone and advance - checks out fine. truck runs with a new battery (figure it's draining it as we speak). runs fine with jumper cables hooked to another vehicle prior to battery change, but the minute you unhook the battery cable it will die within seconds. any suggestions on where my first place to check is for problem? all lights, electrical, etc. seems to be functioning fine until it dies. thanks in advance for any help.
67gmcss2 is offline   Reply With Quote
Old 03-12-2015, 09:27 PM   #2
Wrcampbell
Re: Engine dies
If alternator is charging. Check your wiring harness. Something isnt connected correctly or wire broke. do you have a internal regulated alternator or regulator on radiator support?
Wrcampbell is offline   Reply With Quote
Old 03-13-2015, 06:49 PM   #3
67gmcss2
Re: Engine dies
regulator is on radiator support...
Old 03-13-2015, 08:18 PM   #4
Wrcampbell
Re: Engine dies
The regulator may be bad. It controls the alternator. Do you have a volt meter. If so while engine running test voltage at battery and then at main main at alternator. A alternator should put 13.4-14.5 volts when charging properly. Without seeing your harness and checking your connections,I would have to try a voltage regulator, i dont know if anyone in your area has the know how to test it. But anyhow i would start with that. see if you can find one or borrow one that works and try that first.
The system is a very simple system. Check all your grounds and all fuses. Look for any cracked wires or broken connectors. Good Luck!!!
Old 03-15-2015, 03:03 PM   #5
67gmcss2
Re: Engine dies
thank you wrcampbell. I don't have a voltmeter, but will see if any friends have one that I can borrow and try that route (or borrow a voltage regulator too) and see if it changes anything.
Old 03-15-2015, 03:10 PM   #6
davepl
davepl's Avatar
Re: Engine dies
Remember when testing with alternate regulator that it might need to be grounded (I forget). Don't just hook up the connector.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
