Old 06-09-2014, 04:36 PM   #1
macpro1965
2004 Chevy dually bed on a 1985 C30?
So I scored (free) a homemade/shop built steel flatbed off a 2004 3500 chevy 2wd and I was hoping I could mount it on my 1985 C30 cummins project.
I figure move the mounts around or maybe get some 2000+ mounts to weld on my frame.... I don't know?!?! can someone shed some light on this for me?
macpro1965 is offline   Reply With Quote
Old 06-09-2014, 05:51 PM   #2
donut
donut's Avatar
Re: 2004 Chevy dually bed on a 1985 C30?
Without a picture or how good you are at fab work.... unless someone has done this swap,
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 06-09-2014, 08:17 PM   #3
79Betty
79Betty's Avatar
I seen a 2002ish? Bed on an 80's pickup so i'm sure it can be done. Measure lots and take a step back to compare tire to bed height. Probably gonna have to adjust accordingly.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 06-09-2014, 11:30 PM   #4
mrolds88
Measure twice, cut once.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 06-10-2014, 11:04 AM   #5
macpro1965
As soon as I pick up the bed Ill post some pics of it.
Old 06-10-2014, 04:16 PM   #6
trout
I know it's a crew but it is a short bed
Edited by staff
trout is offline   Reply With Quote
Old 06-10-2014, 05:30 PM   #7
donut
donut's Avatar
I'd assume some fab work, especially if you plan on keeping it a short bed. For the cost of materials, you definitely made out.
Old 06-10-2014, 07:52 PM   #8
trout
Sorry I posted in wrong thread
Edited by staff
Old 06-10-2014, 08:07 PM   #9
Axle
Axle's Avatar
If it is a flatbed, they often get mounted with basic plates that tie the truck frame to the frame of the flatbed by simply bolting them together.
Some flatbeds get mounted onto a contoured wood middle layer, and clamped to the frame (couple plates across the frames and some bolts or allthread to clamp it). Look under a commercial box truck for that style. Its a semi-floating design, intended to keep the frame flexable and help prevent cracking that the 1st method of solidly bolting the two together could potentially cause as the box or flatbed would make the back half of the frame stiff as all can be, leaving the front half to do all the flexing.
Does mounting type matter on a pickup? Probably not, lately I've noticed that most flatbeds now are solidly bolted to the frame. In any case, you may need to fab up some new plates, or cut some wood for the sandwich. =-)
[basic solid mount]
[wood sandwich with a solid mount]
[commercial box with wood sandwich and "clamped" in place]
Alex.
Axle is offline   Reply With Quote
Old 07-24-2014, 01:44 PM   #10
macpro1965
Here is the flat bed....boy is that thing heavy!
Old 07-24-2014, 03:13 PM   #11
donut
donut's Avatar
WOW, looks it, suspect the 4 pad eyes are so the crane can pick it up, lol.
Start measuring and see what you can do. Don't know about the mounts underneath, that'll be on you. I do suspect that bed may be wide for what you want. (Kickout running from front to back looks like for a dually pickup, SRW, you may want narrower.)
Now, you can decide how to procede. Sometimes the truck frame is the best place to set it down so you can work on the bed. Or make the decision to throw it on CL and build what you want from scratch.
Old 07-24-2014, 04:35 PM   #12
stroker87
my father had a dodge flatbed mounted on his ford, the guy that did the instal laid c channel across his truck frame then put the flatbed on top of the C channel welded it up we never had a problem used it for quite a few years and it was abused really, had the truck way over loaded many times
the reason he used C channel was the ford frame was wider then the one on the flatbed, was cheap and easy too
they give you an idea on what that one weights? it might be on the heavy side for your truck and kill MPG too
stroker87 is offline   Reply With Quote
Old 07-28-2014, 07:43 AM   #13
macpro1965
Yea it is going on my 1985 dually project truck; the guy who built it was planning on putting a sled on the bed with welding equipment that was able to be removed. The truck it was on had it welded directly to the frame and they did a piss poor job with the removal so I have some holes to weld up.
