![]() Join Date: Jan 2015
Adding Disc and lowering Fr&Rr...
Ok I have been reading threads and searching sites for a week... I want to lower my 68 3/5(?) and upgrade brakes from non power drums to power disc. I also want to change from the 6 lug to 5 on 5 lug.
I have seen many kits to do one or the other, but nothing that does both. I am niether for nor against kits or piece mealing it out... which ever way to get the parts together to get the job done. So anyone have a parts list or manufactor that can help me? Jimmy |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Adding Disc and lowering Fr&Rr...
#3 | |
If I order the axle conversion from them, what rotors and calibers will I need? And when you order the 4/6 drop kit for $799 you get the 2 1/2" drop spindles as do you when you get the disc brake conversion kit for $759??? Can't use two sets of drop spindles... And do these all bolt up to my stock A-arms? Jimmy |
Moderator
![]() Join Date: May 2007
Call them and talk to Stan. He will fix you up with what you need and answer your questions.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
http://www.classicperform.com/Store/...6772GSK-5D.htm
I haven't used this kit, but this is one I was considering because I am looking to do the same thing you are looking at on my '67. The thing that looks good to me on this one is it comes with everything, which is a huge selling point for me. The only thing this doesn't include that I would need for my truck is rear axles to convert them to 5 lug, but I am leaving the rear as drum brakes. |
Look in the review area for feedback from members before you
order from CPP. You have been warned.
I'm considering doing almost the exact same thing to my 70 except I have power drums now. still thinking about replacing the booster and master though. I'd be interested to see what you end up going with. I have a little time before I pull the trigger on my upgrade, so please post who you go with and the results you get.
I do know that Early Classic offers a kit that combines the 4/6 drop kit and disc brake conversion kit for $1299. But that's as far as I got. Give them a call or email them at sales@earlyclassic.com. They're usually pretty good at getting back to you.
![]() Join Date: May 2013
If you get the cpp kit plan on using different shocks mine lasted less than a month
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#10 | |||||
Called Stan...very knowledgeable guy! He is emailing me all the prices! Quote:
Thanks for the heads up! Quote:
I plan on using the kits available from ECC! Stan can put a kit together for your personal needs! I will not be tearing into this project for another couple months, just buying parts ahead of time. Quote:
Just got off the phone with Stan! Very impressed with him. Quote:
Not going with CPP.... |
#11 | |
Senior Moment
![]() Join Date: Mar 2002
All my suspension is ECE , Front and Back
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Ok, after talking to Stan at ECE (for an hour!) I think he has everything worked out for me.
I am going with the 4/6 drop for sure. Converting over to power steering(thanks to Stan!).Jimmy Last edited by Dustmaker65; 02-06-2015 at 06:10 PM. |
Moderator
Rear disc is unnecessary, unless you have open wheels and want some bling.
You will be pleased with ece ,they are top notch.
#15 |
Rear disc is nice if you have money to burn.
Otherwise it's not neccessary. You are on the right track with ECE.
#16 |
Hmmm...still patiently waiting for that email from Stan with parts and prices....
Jimmy |
