Old 08-27-2014, 05:10 PM   #1
FL71C10
Disc brake conversion on 4wd truck
I am looking at buying a 67 Chevy 4 wd truck and would like to convert the front to disk brakes. Is that harder with a 4 wd?
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 08-27-2014, 05:55 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Disc brake conversion on 4wd truck
If you do a search you might find a thread about converting. I think most just install a later front axle.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-27-2014, 09:34 PM   #3
FL71C10
So I would swap the front axle with one out of a 71 or 72 truck?
Old 08-27-2014, 10:11 PM   #4
69chevytrucker
69chevytrucker's Avatar
up to 87
69chevytrucker is offline   Reply With Quote
Old 08-27-2014, 10:12 PM   #5
franken
Up til about 70 they used closed knuckle and drum brake systems. Its often easier to swap to 71+ closed knuckle disk systems.
Blazers?, and subs didn't change body styles til 91 so there are a lot of doners.
Old 08-27-2014, 10:14 PM   #6
69chevytrucker
i know with the 2wd models up to 87 and im pretty sure it will work 4x4 too cause i got a 69 2wd with a 85 front end and i got a 83 blazer and im thinking on doing the swap to make it a 4x4 now
Old 08-27-2014, 10:50 PM   #7
FL71C10
So I would probably want to swap out front and rears from a later model donor
Old 08-27-2014, 10:53 PM   #8
69chevytrucker
not if you dont want 83 blazer is 6 bolt so it would match the 67
Old 08-27-2014, 10:54 PM   #9
69chevytrucker
but if you got the doner truck then switch what you can newer is better anyway right
Old 08-28-2014, 07:15 AM   #10
CUSTOM/10
CUSTOM/10's Avatar
I believe 71-87 all front diff's will bolt in. At some point around 78 gm went to a corporate 10 bolt front but it will still bolt in. The rears will only bolt in up to 72, after that you would have to relocate spring perches & shock mounts. And again GM went to a 10 bolt from the 12 bolt I believe around 78. There are other subtle differences IE: larger brakes, slightly wider axels ext. But you can make them all work. Just make sure your front & rear gear ratios are the same !!!
I'm sure other members can give you even more details about yrs and there differences.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
