Old 09-02-2014, 01:42 PM   #1
burningsquirrels
Need help/question - 327 road draft pcv question?
Hey folks, some back story first. So I have a well-running, relatively new-to-me 67 C20 with a 327 and 4 speed. I was running a bunch of errands one day and put close to a couple hundred miles on it one day and noticed it could barely hold an idle towards the end of the day. After some troubleshooting I found that it had the symptoms of a vacuum leak. Cover the carb, and idle shoots up. I checked all the hoses and timing, the timing was pretty far off. The hoses... The road draft tube went straight to the large manifold port on the carburetor with no PCV valve - I guess that was the vacuum leak!
After reading some threads on herere, I decided that I was going to try and seal up the 'hat' in the back of the engine block. I started by putting a vacuum cap on the tube that leaves the hat. I then took the hose from the manifold vacuum port on the carburetor and ran it over to a PCV valve that sits on one of the breather holes for the valve cover (the breather on the driver's side is still there). That, combined with the timing adjustment, I was able to adjust the idle speed screw down a bunch. I guess it was set very high because of the original issue. Now the motor runs great and better than ever!
Problem: It now pukes oil out the back of the motor and has a James Bond quality smokescreen wherever I go! When I say oil, it's leaking from somewhere and I guess it's burning off the headers. It's all underhood. With regards to puking oil - it's somewhere from the back of the engine. I hosed it off (just the back, of course, away from the top end) to clean off any oil and went for a drive. Did a lap, and it started smoking again. I parked and checked the various places from the back using a clean white paper towel to look for oil traces. Didn't seem to be a rear main seal, or the valve covers. The distributor and back of the intake manifold looked okay. It seems like it may all be coming from the 'hat' thing on the back of the motor. I took it off, cleaned the hat and the hole, and tried using ultra black over there as I couldn't find a gasket online, and I didn't have any o-rings big enough. That didn't seem to help as after a test run a couple days later, it was soaked in oil again.
So I guess my question is, how is that 'hat' thing supposed to seal against the block from the factory? When I removed it there was no trace of a gasket, and I don't recall seeing an indented ring for an o-ring on it? I saw a thread that mentioned a block plug but haven't found anything smaller than a complete kit. What do you folks suggest?
Thanks!
burningsquirrels is offline   Reply With Quote
Old 09-02-2014, 02:39 PM   #2
kwmech
Re: Need help/question - 327 road draft pcv question?
Measure the hole and put in a freeze plug with a little bit of sealer
Old 09-02-2014, 02:45 PM   #3
leftybass209
leftybass209's Avatar
Your engine needs to vent..... or else exactly what you described can happen. I'm assuming you're 327 has stock valve covers with no holes, and an oil filler tube in the front with a breather cap? You had a long winded message so I'm trying to put together the details. Pics may help as well.
leftybass209 is offline   Reply With Quote
Old 09-02-2014, 03:10 PM   #4
Lattimer
Lattimer's Avatar
Read closer----he said he has a breather and a PCV valve installed in the valve covers.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 09-02-2014, 03:12 PM   #5
Lattimer
Lattimer's Avatar
Best thing to do is use a freeze plug in the hole at the back of the block for the draft tube. That will seal it up and should resolve the issue if thats where the oil is coming from.
I used to have a small journal 327 and the draft tube hole had been plugged like that.
Shawn
Old 09-02-2014, 03:17 PM   #6
leftybass209
That's what happens when you search the forum on a phone. Good catch! Now I can firmly agree with plugging the Draft tube hole.
Old 09-02-2014, 03:21 PM   #7
Lattimer
Lattimer's Avatar
LOL----I miss stuff all the time like that. Just can't read it good enough on the small screen.
Shawn
Old 09-02-2014, 08:48 PM   #8
burningsquirrels
thanks guys for the suggestions.
yes, i'm running newer style valve covers. one side with a breather, the other i set up like my 69 nova - with a PCV that goes in the breather hole. i decided on that after searching on and reading some of the older threads that had some pics. the intake manifold is an edelbrock performer plus so no oil filler tube up front.
i should be able to look and measure tomorrow. as i perused the internet, should i grab brass or steel? i would think brass would be easier to install.... i appreciate the multitude of responses - thanks!
Old 09-02-2014, 10:26 PM   #9
Lattimer
Lattimer's Avatar
I'd go with brass.
Shawn
