Old 10-30-2011, 09:49 AM   #1
Harley1650
1963 C-10 BBC/Muncie 4 spd
Harley1650's Avatar
Low hump or high hump
My 63' has a big block and a Muncie 4 speed. I'm considering switching to automatic and became aware of different humps.
Does 63' have a low hump and high hump options?
How would I tell what I have?
If I switch to a 350 trans would I need one or the other for clearance?
Harley1650 is offline   Reply With Quote
Old 10-30-2011, 11:06 AM   #2
63CHEVY62GMC
63CHEVY62GMC's Avatar
Re: Low hump or high hump
Yes. the model with the 3 speed tranny had the low hump. the model with the four speed had the high hump. post a pic of yer interior and ill tell u wat u have. and about the th/350 trans, im not shure. id guess the high hump.
63CHEVY62GMC is offline   Reply With Quote
Old 10-30-2011, 11:11 AM   #3
LT1 Burb
LT1 Burb's Avatar
My auto truck has a low hump.
LT1 Burb is offline   Reply With Quote
Old 10-30-2011, 12:19 PM   #4
dodgiesdad
dodgiesdad's Avatar
I have a 350 auto with a low hump as well.
dodgiesdad is offline   Reply With Quote
Old 10-30-2011, 04:01 PM   #5
Harley1650
Harley1650's Avatar
Old 10-30-2011, 04:21 PM   #6
Joemomma1
Joemomma1's Avatar
That I believe is a high hump sir.
Joemomma1 is offline   Reply With Quote
Old 10-30-2011, 04:22 PM   #7
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I beg to differ, you have a 3 speed column shift or Automatic Hump, See how it curves back up at the seat.
The four speed High Hump goes almost level from the front to the seat.
Old 10-30-2011, 04:31 PM   #8
Harley1650
Harley1650's Avatar
It was originally a 3 speed column shift
Old 10-30-2011, 05:19 PM   #9
Joemomma1
Joemomma1's Avatar
Ah ha! My knowledge leaves something to be desired. My appologies.
Old 10-30-2011, 05:43 PM   #10
Harley1650
Harley1650's Avatar
OK, it appears I have a low hump. And I saw a couple posts that a 350 tranny will fit?
Old 10-30-2011, 07:51 PM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
Here are a few pictures I pulled off the net that should make identification a little easier. A high hump pan is almost square in the center, rises up in front of the seat, and is always removable:
The low hump drops in front of the seat, may be removable or may be a permanent part of the floor. From all the threads I’ve read on this topic, they are not directly interchangeable, however a high hump can be added to a low hump truck if the portion from the high hump donor truck in front of the removable pan is also cut out and welded into the low hump cab.
Old 10-30-2011, 07:54 PM   #12
Leadfoot Lambert
Leadfoot Lambert's Avatar
Does anyone have a spare removable low hump kickin around?
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 10-30-2011, 11:54 PM   #13
aerotruk63
aerotruk63's Avatar
I believe it's a year issue. My 63 has a removable low hump but the black 66 that I sold had an integrated low hump.
Old 09-10-2014, 09:59 PM   #14
Blu64c10
I was searching to find out what type of hump is in my truck and discovered a pic prior to me owing my truck was used as an example. Where did you find that high hump pic Markeb01?
Blu64c10 is offline   Reply With Quote
