PVC and brake booster plumbing, is this a bad setup?
Just read that pcv should have its own vacuum, is this a bad setup? All parts seem to function correctly but a haven't taken it out and given it h3ll. I just took it out for a couple lazy drives.
Re: PVC and brake booster plumbing, is this a bad setup?
Wiring will be moved, I'm workin on that now.
#3 | ||
"I ain't nobody, dork."
It's the other way around... the booster should have it's own vacuum line so it gets full vacuum from either the intake manifold or the carb. The PCV can be T'd in to another vacuum source.
Gary
Correct. you can have very small things connected with the booster but a PVC is not one of them. Things like tranny modulator, distributor vac advance are ok since they don't draw any flow away from the booster.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
#6 | |
http://www.fastenal.com/web/products/details/69945 |
Last time I needed one the local NAPA had all of those fittings in stock.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Thanks everybody, ill take your advice and get that sorted out.
#9 | |
#10 | |
Fitz, when you say the brakes might not work, do you mean that the boost will not work, making the effort to brake be that of manual, non-assisted brakes? Or do you mean a complete failure of the brakes? I ask because it has been on my mind to be rid of my brake booster.
The little check valve assembly is supposed to act a check valve for vacuum and hold the vacuum in the booster more or less at the highest point available. It is the surprise factor that Fitz is speaking of. The brakes will operate but if vacuum or is insufficient it will feel like manual brakes. The surprise will feel like you're trying to push a cinder block thru the floor boards when it should be smooth and nice. The port that is pictured is where I tapped from for my 250 as well, thinking 1/2 NPT"???
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! ![]() My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
