Old 09-12-2014, 02:41 PM   #1
ACII
fuel pressure regulater, instead of Corvette fuel filter ??
Hy all
one more question about the fuel filter setup ... :-)
Actually i am thinking about using a fuel filter regulator like this one here instead of the C5 Corvette filter...
http://www.ebay.com/itm/Red-ADJUSTAB...a4ca07&vxp=mtr
I want to use that kind of regulator because i am gonna installing a turbocharger in a few month..
I guess i need more than 60 psi with a turbo setup, so i cannot use the original corvette filter anymore...
So pls let me know if this setup (parts) could work ?? :-)
fuel pump --> adjustable fuel pressure regulator --> fuel filter --> engine
I just dont know how it goes with the return line... the engine is of a 99 Camaro Z28...so there is not return line / connection at the intake manifold.
Can i just plump a T-Divider between fuel pump and fuel regulator ???
sorry again for my english
Achim
ACII is offline   Reply With Quote
Old 09-12-2014, 02:58 PM   #2
boostedc10
boostedc10's Avatar
Re: fuel pressure regulater, instead of Corvette fuel filter ??
ACII running a turbo does not require an increase in fuel pressure. What you need is sustained volume.
I would convert to a return system at this point. Plumbing is easy with an aftermarket regulator.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 09-12-2014, 03:19 PM   #3
ACII
Hy
ok thanks for information...as u can see i am pretty new to the topic turbocharger :-)
what do u mean with converting to a return system ?
How does it work and why ?
Achim
Old 09-12-2014, 03:36 PM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
It does from a standpoint that it should be boost referenced, in order to keep the flow across the injector constant as boost increases.
ACII, a return system is like the schematic below. That's how I run all my LS swaps, since the injector flow-rate remains constant, and it makes tuning a little easier.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 09-12-2014, 03:48 PM   #5
ACII
Thanks.....i understand :-)
So i need new rails ? or can i use the stock ones ???
Old 09-12-2014, 03:49 PM   #6
boostedc10
boostedc10's Avatar
If you were trying to use the Vette regulator I am assuming your motor is setup as a return-less fuel system. Return-less systems have only one line on the intake manifold and fuel pressure is typically regulated at the tank, or at the filter in the Vettes case.
The questions is what is your horsepower goal and budget for the fuel system?
With higher horsepower applications you have much more control over the fuel pressure and eliminate surging caused by a return-less system. Return systems also handle big fuel demand swings much better.
The biggest down side to the swap is the cost because you will need new rails, a fuel pressure regulator, filter, and an added line back to the tank.
Brandon
Instagram: DRVFSTR
Old 09-12-2014, 03:52 PM   #7
boostedc10
boostedc10's Avatar
Got me on a technicality and posting my last post to slow!!!!
Brandon
Instagram: DRVFSTR
Old 09-12-2014, 04:11 PM   #8
ACII
My goal is around 500 to 550 horsepower at the crankshaft
So i will definitly go like the diagramm of "wasted income"
The fuel pump / regulator / filter i can easily buy here in Germany.. but for the fuel rails i have probably to order some of the states...
Or can i use some of the older vette models or LT1 engine ??
Achim
Old 09-12-2014, 04:22 PM   #9
boostedc10
boostedc10's Avatar
Wo wohnst du? Ich arbeite für VW und kann vielleicht helfen.
Brandon
Instagram: DRVFSTR
Old 09-12-2014, 04:40 PM   #10
ACII
jetzt bin ich leicht überrascht :-)
Ich komme aus Ulm ..liegt genau zwischen München und Stuttgart.
Bist du Deutscher oder der deutschen Sprache mächtig ?
Gruss
Achim
Old 09-12-2014, 08:13 PM   #11
boostedc10
boostedc10's Avatar
Lol nicht sein, ich arbeite für eine Firma Deutsch! I bin Amerikaner aber sprachen ein bisschen Deutsch.
Meine schriftliche Deutsch is nicht so gut!
If you ever need anything brought over, I travel to Germany a few times a year so let me know.
I am usually in WOB which is a little ways away but I am sure we can figure something out.
As for the fuel rails on the car intake I am pretty sure you have to go aftermarket unless someone here knows of a car intake with a return line,I don't.
Brandon
Instagram: DRVFSTR
Old 09-13-2014, 10:47 AM   #12
dayj1
'97 and '98 Corvette LS1 was a return style system.
dayj1 is offline   Reply With Quote
Old 09-15-2014, 02:48 AM   #13
ACII
Hy all....
does anybody know these parts ?
http://fasster.com/LS1-LS6-high-flow...-6BLKrails.htm
What do u think about the quality ?
@ wasted income
Could i plumb the regulator directly between the two rails.....i do have fuel regulator with two inlet ports....and a return port at the bottom of the regulator, so the setup would look like a T-Block
Or do i definitly need the return Y-Block for a better flow ?
Achim
Old 09-15-2014, 09:23 AM   #14
Wasted Income
Boosted Member
LOL it's all good, man. You know that I know that you know what you're talking about
Originally Posted by ACII View Post
@ wasted income
Achim
The way you are talking about is exactly how I plumbed mine. The pic I attached is the best one I have of it right now, but I ran two hardlines to the inlets on the regulator, and came out the bottom with the return to tank.
Turbo diesel
Old 09-15-2014, 12:00 PM   #15
Wasted Income
Boosted Member
ACII, clear out your PM inbox...I can't respond to your PM until you do
Turbo diesel
