Old 09-20-2014, 11:30 PM   #1
Denny55
Denny55's Avatar
Back-up lights
Anyone have ideas on back-up lights for a 55 second series? I can't find anything small yet bright enough. I would like to put them on the panel above the bumper and under the tailgate.
Denny
Denny55 is offline   Reply With Quote
Old 09-21-2014, 02:16 AM   #2
tinyjaime
Re: Back-up lights
http://www.alanhorvath.com/54chevy/backups.php
tinyjaime is offline   Reply With Quote
Old 09-21-2014, 10:28 AM   #3
Chris.
Re: Back-up lights
https://www.chevsofthe40s.com/detail...e_Reverse.html
Chris. is offline   Reply With Quote
Old 09-21-2014, 03:17 PM   #4
Russell Ashley
Russell Ashley's Avatar
Re: Back-up lights
Originally Posted by tinyjaime View Post
In case anyone else doesn't know how to get the tailgate off, there's a hole in the bottom of the tailgate, and a slot in the pivot trunion. You put a screwdriver or something through the hole into the slot and that locks the trunion so the bolt can be removed. TF's have this hole so I assume AD's do also.
Russell Ashley is offline   Reply With Quote
Old 09-21-2014, 10:51 AM   #5
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Back-up lights
I thought the bed roll lights would be a little cheaper at Mar-K, I was wrong. They must buy them from the same place.
http://www.mar-k.com/Catalog/m/mItem...ID=8245&CID=10
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 09-21-2014, 12:55 PM   #6
1project2many
Re: Back-up lights
In '58, reverse lights were available as a dealer accessory. Part no 987454 covered trucks and Suburbans. The rear lights appeared to be the similar to the white front lights for 55-57 trucks. I posted the instructions in another thread.
http://67-72chevytrucks.com/vboard/s...84&postcount=9
If you choose a light with a 194 bulb, there is a 2 watt plug in replacement available that is used in European cars. I believe the Sylvania number is W2W.
Hmmm... These might work well.
http://www.ebay.com/itm/BRAND-NEW-Pa...item19d3decbfc
1project2many is offline   Reply With Quote
Old 09-21-2014, 07:51 PM   #7
Denny55
Denny55's Avatar
Re: Back-up lights
Thanks to all. I like the bed roll idea, but they aren't cheap. I also like the look of the Alan Horvath idea. I might look for these and other marker or signal lights that can be re-purposed. Thanks again...what a great site!!
Old 09-21-2014, 08:43 PM   #8
Nordic
Nordic's Avatar
Re: Back-up lights
I used a set of driving lights from a custom van.
Nordic is offline   Reply With Quote
Old 09-21-2014, 10:57 PM   #9
Denny55
Denny55's Avatar
Re: Back-up lights
Good idea and well hidden. Also the least invasive and probably the easiest to install.
Old 09-22-2014, 04:11 AM   #10
tinyjaime
Re: Back-up lights
If you also taking about bed roll lights here is what one of the Stovebolters did. Here is the whole post so you can follow the history of the forum http://www.stovebolt.com/ubbthreads/...=973073&page=1
Here is how he did it
Two pack of HF LED flashlights $2.99:
http://www.harborfreight.com/led-fla...-12-69065.html
Two 1-1/4x 3/4 PVC reducer bushings $1.59 ea.:
http://www.menards.com/main/electric...005-c-6424.htm
Five pack of carbon film dropping resistors $1.49 (two used):
http://www.radioshack.com/product/in...ductId=2062323
Red tail light lens blister pack from Wal-Mart trailer parts rack $3.59 (makes 4 lenses).
This picture is taken at an angle, LED's are very directional as
opposed to an incandescent bulb. How bright you say? Shine one
of these 7LED cluster flashlights in your face and you'll see
it first hand:
http://www.pbase.com/dennygraham/ima...37355/original
Denny Graham
Sandwich, IL
